Hp 1440 storage easy problem
Roger
hello every one
i am new to servers world so if you can help me with my problem its very kinds of you
my problem with hp 1440 storage easy i purchase new one and attach to it 2x3TB SATA DRIVES AS FOLLOW IN THE PICTURE
I Have 2 array control  dynamic smart array B120i and the Second one is the smart array p222
i disable the B12i and use only the P222 (tell me if i wrong ! )
i create array consist of one logical drive which combine the 2 drvers 2x3TB as below picture
when i wont to install windows 2012 standard evolution
the following error appear
Best thanks for you
Not sure about the error.
Did you partition the drive to come up with the 1.5TB drive? I would recommend installing the OS on a small SSD and leave the big drives for your data.
As for the B120i or the P222. This system has both. I would use the P222.
The StoreEasy is a HP Server that runs Windows Storage Server OS. The 1440 is a DL360e. Is there a Windows License key on the chassis or in the paperwork that came with the unit? The specs are on page 57:
http://www8.hp.com/h20195/v2/GetPDF.aspx/c04111444.pdf
My only concern about using this server is it may have some customization in the bios. If possible I would try to get it back to a DL360e bios or I would load the Storage Server software and use it that way.
