Questions on Planning and Preparing for a Gen8
darkarn
Hi guys, after some more reading up and asking around, I decided to consider the Gen8 too alongside with the N54L, here's some of my questions:
Questions
1. Will it be harder to maintain a Gen8, especially in getting BIOS updates and drivers with the current state of HP's support? (Expectations)
2. Should I save that single PCIe slot for a graphics card, or is it better used for something else? (Hardware)
3. How can I use the dual NICs well? (Hardware)
4. For my use cases, will the lowest CPU be alright? (Hardware)
5. Which OS I should go for? Or will hypervisors (i.e. ESXi) be more suited for my use cases? (Amahi, Ubuntu, WHS/Windows 8 are my top choices currently) (Software)
6. If I were to go for a hypervisor, what should I look out for? (Expectations/Software)
Thanks! (Below is more background data that I hope will come in handy)
Current Setup
Computer(s): 1 Sager NP8170 (HDD changed into a Crucial M550 256GB)
Main Storage: 1 HGST 3.5" 3TB Deskstar HDD in a Hotway USB 3.0 external enclosure. Connected to my laptop as Windows 7 local drive via USB 3.0.
Backup: 1 3.5" 2TB HDD, 1 3.5" 1TB HDD in a shared PC. Connected to my laptop as Windows 7 network drives over the home network (i.e. PC to router, router to laptop).
Router: Asus RT-AC66U
(All drives above are formatted in NTFS)
Planned Setup
Main Storage: 1 3.5" 2TB HDD, 1 3.5" 1TB HDD in a Gen8. (Gen8 to switch, switch to laptop, switch to router)
Backup: 1 HGST 3.5" 3TB Deskstar HDD in a Hotway USB 3.0 external enclosure. Connected to my laptop as Windows 7 local drive via USB 3.0.
(Not sure if should stick with NTFS due to OS choice in the Gen8. I prefer not to reformat if possible.)
Use Cases
1. Storing my data in my HDDs and being able to access them (i.e. NAS) (High priority)
2. Monitoring HDD health with real-time alerts (High priority)
3. Media streaming (in home network mostly, but if can be done ) (Medium priority)
4. Production server for web projects e.t.c. (LAMP setup maybe?) (Medium priority)
5. Media transcoding (then again, I think my devices can handle untranscoded stuff...?) (Low priority)
6. Creating an environment where I can learn the usage and deployment of servers for fun and for career (yes, I know, this sounds naive at best...) (??? priority)
Items to Get/Prepare
Gen8 itself
HDD/SSD since none will be supplied
DDNS Hostname for router (done!)
Switch
Thumbdrive with OS and BIOS mod if need be (need to decide OS first)
Extra Ethernet cables for the setup
I hope this is not too much... Thanks!
Questions
Once a server is running OK, I don't bother with updates unless they are to patch a security or performance issue. Generally a server just runs in the corner and isn't subject to the normal use that a PC will get, so updates are not as important.
I can't see you have any need to use the slot.
If you have lots of clients, you could channel bond to increase the LAN capacity but be aware that you will only get a max of gigabit per client.
Your biggest CPU load would be transcoding. the basic CPU should transcode a single HD stream fine.
​I wouldn't bother with an OS - just use FreeNas or Xpenology
If you are doing this for career, then I would suggest ESXi as VMWare is probably more useful on your CV than the others.
Current Setup
Planned Setup
Use Cases
All the above could be done with FreeNas. You have the added advantage of Jails where you could deploy a LAMP stack, or the VirtualBox plugin could be used.
If you want to play with deployment of stuff, I would get yourself a cheap N36/40/54 or something as well. You don't want to be messing with your real backups etc by experimenting. The best way to learn is to break things and fix them again!
Gen8 itself
Switch
Thanks for your reply!
1. Hmm... I am asking as I understand that you have to download patches for the server once you open it out of the box to avoid the red screen issues, does not having a warranty plan (is that how you call it?) affect this?
5. How is FreeNas or Xpenology better than the OSes?
6. Looks like I need to check out how to get ESXi for free/low price...
Would love to have a N54L to play with but I can only afford either the Gen8 or the N54L :D
I understand that I cannot run the virtual OS 24/7 in VirtualBox unlike ESXi right...?
If its a new machine, you should have a years warranty that you can download updates once you have registered the serial number on the HP site. If its not new, there is a link on here somewhere for the latest SPP ISO that contains all the driver updates rolled into a bootable disk that can be mounted over iLO.
Its a simple all-in-one point and click software. Yes, you could set what you want up using an OS, but its not an all-in-one solution and requires periodic maintenance. Personally I like to keep things simple :)
ESXi is free for personal use, limitation is that you can only use the Windows vSphere client for management (or the new beta web management fling) but for basic use thats fine.
If you go this way, make sure you create VM's as version 8 though; to edit some features in later versions needs the VCSA web management appliance which isn't free.
As far as I know, the FreeNAS VirtualBox plugin just runs in the background, so as long as the server and FreeNAS is running (and VirtualBox jail started), your virtualised OS will be running...
Edited by snapper
1. Thanks! This is one of the major concerns I have over HP's stuff ever since I heard about that warranty issue...
5. I see, but I understand that I will have to reformat my HDDs from NTFS into ZFS if I were to use FreeNAS?
6. Sorry, I am still a wee bit confused about this; I heard that some versions (5.2 and below?) are totally free, while the others are free but the tools to manage it are not free (effectively making it not free)?
7. Ah I see, didn't know that I can run it in the background...
Yeah but the Gen8 line is being replaced by the Gen9, so updates are going to tail off anyway as they concentrate on the newer devices...
Yep, but you will have to do this as well for any other non Windows OS, including ESXi.
The only way around this with ESXi would be to get an additional HBA card and upgrade to a Xeon CPU and use PCI Passthrough to present the NTFS disks directly to a WIndows OS.
The basic ESXi hypervisor is free for home use, as is the depreciated vSphere Windows client (although it still works fine with a few limitations).
The preferred management tool is now VCSA which is paid for.
You can use ESXi fine at home with the Windows client, or if you are a non Windows user, there is a free web based management UI in beta.
At work we have the fully licensed VMware, but at home I use the free edition and haven't found anything that I need at home that cannot be done with the free licence/tools.
Edited by snapper
1. Now that we are talking about Gen9... Feels like I should wait it out but then again, something tells me that even if Gen9 comes out, it will be too expensive for me :S
5. I see, looks like I should double-check the OSes before installing...
6. Thanks, that clears up quite a bit! So they just want us to pay for whatever that controls the ESXi?
