HP Stream mini SATA Cable
Dave
I picked up a Stream mini desktop from woot.com for $150 and have been having trouble finding the SATA cable in order to add a 2.5" HDD or SSD.
http://www.ebay.com/itm/Ribbon-Cable-Prius-SATA-L-65mm-PR2-794966-001-for-HP-Stream-Pavilion-Mini-/151793930685?hash=item23579f91bd
This cable on ebay is 1/3rd the cost of my mini!  Has anyone found a source for these cables?
GotNoTime
yodafett found a HP cable that could be easily modified to fit his Dell. I wonder if it'll fit your HP Mini?
schoondoggy
The picture of the cable looks just like the one yodafett used. It also looks like the one I used from the link above.
This is a ebay search of the same part yodafett referenced:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.TRS5&_nkw=6017B0421501&_sacat=0
How does $15 work?
One thing I ran into Dave is the copper leads will detatch as you insert it, I was able to straighten them out and on the cable appears to be working ok but FYI
