Chrome Remote Desktop and 2011
awraynor
I have one specific need for this, albeit due to a problem with my favorite program.
I run Plex MediaServer on my 2011 box and have only one frustrating problem with it. Fairly predictably, but not always on schedule the PMS will be available from my devices or
the Plex website. I simply have to logon the server, open the app with everything refreshed and all is good with the world again.
Of course this is most likely to occur when I am out of town and want to view media and then discover it has "timed out" again. I haven't found a setting for it to never time out.
I tried Chrome Remote Desktop and it works fine on Win8, Win10, but with 2011 all I get is a black screen when I connect.
Has anyone tried or have an idea about this problem?
Could it be a video resolution issue? What resolution is your server running?
Does it need to be Chrome Remote Desktop? Could you try TeamViewer?
I will have to check tonight, using onboard video and no monitor is connected.
I was trying Chrome Desktop for convenience. I have used TeamViewer to connect
to other computers remotely, but only in the situation where they would generate a code
and I would enter it on my end.
Can you have a static user/password on TeamViewer for your own machines? I don't need to connect from outside the home often, but it's frustrating when I can't due to needing to
refresh Plex.
Even TeamViewer doesn't work. Throws error about Fast User Switching which I have turned off and still no luck.
Also mentioned RDC which I am not using to connect at the moment.
I installed it within the last few days straight from the Chrome "extension" store. There are no listed updates, it will still access
the server, but the screen remains black.
Things are a lot better now ;) I accidentally applied do not allow remote connections to this PC. Now I can't connect via the dashboard, or even RDC
to change the setting.
Even better when I connect a cable to the server it doesn't output video through the HDMI or VGA onboard connections. So I basically have a
blind server unless you can think of a way to access the settings that I can't.
CRD still isn't working, but at least I can remote in again.
Took the video card out of my desktop so I could access the server and enable remote connections again. Still no VGA output even though the driver
for VGA says everything is okay. Don't see a VGA option in BIOS, I guess that is understood.
TeamViewer is working okay, so I'll go that route and forget CRD.
