Proxmox with smartarray : still stuck at 30-40% fan speed
DannyBiker
Hello guys,
Here's my setup :
Microserver Gen8 (duh !) with four disks in : 3 standard 3.5 HDD for storage and one SDD (installed through an Icybox adapter) running Proxmox and its VMs.
I recently realised that I'm constantly running at 30 to 40 % fan speed, in any condition - probably due to the lack of proper drivers. I'm kinda disappointed about this because I specifically avoided using the AHCP/Legacy modes and stuck with Smartarray to avoid the known fan speed issue running them.
I flashed the most recent Service Pack so I should be up to date when it comes to drivers, etc. iLO is at version 2.1 I think.
Is there any way to reduce the fan speed ?
Start with updating the following:
iLO to 2.20
BIOS to the latest (if it isn't already set)
SmartArray controller to the latest firmware (if it isn't already)
If that doesn't resolve it (it may not), can you report to us the temperatures your iLO is showing within the system?  This may be determining your fan speeds.
Also, what fan speed profile is set in your server BIOS?
    • Haxsource
      By Haxsource
      Good afternoon folks!
      I have a question I was wondering if someone would know about. I have a Microserver Gen 8 with Vmware ESXI 7 currently installed on the MicroSD with AHCI enabled instead of RAID mode (dont find anything usefull in raid mode in my current setup other than booting from ODD, which I can just use as another Datastore instead).
      With that context being said, Im trying to enable the Agentless Management Service from the ILO with the drivers on the Vmware ESXI 7, but unfortunetly after installing and trying to start the service with:
      /etc/init.d/hp-ams.sh start
      I get the following error:
      /opt/hpe/ams/amshelper: error while loading shared libraries: libnicmgmt.so.0: cannot open shared object file: No such file or directory
      Makes sense following the Vmware ESXI HPE support matrix, since its only supported until Vmware ESXI 6.5U2 Pre-gen. But I´ve been reading lots of people having working setups doing the following:
      Install Vmware ESXI HP Custom Image 6.5U2 -> Offline Update to Vmware ESXI 6.7.
      I was wondering if installing HP Custom Image 6.5U2 with the drivers Agentless Management Service working and doing a full upgrade to ESXI 7.0 would do the trick, since its an upgrade not a clean install...so libraries should stay supporting older drivers installed.
      Does this make any sense?? Has anyone gone trough this alredy?
      Thanks!
    • netware5
      By netware5
      ***CRITICAL*** iLO 4 update available here. HPE requires users update to this version immediately. Potential vulnerabilities in network stack.
      VULNERABILITY SUMMARY
      A potential security vulnerability has been identified in Integrated Lights-Out 5 (iLO 5), Integrated Lights-Out 4 (iLO 4), and Integrated Lights-Out 3 (iLO 3) firmware. The vulnerability could be remotely exploited to cause memory corruption.
      HPE has released updated firmware to mitigate these vulnerabilities.
      References: CVE-2020-27337
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • gru
      By gru
      Hi! I am planning to buy a Microserver Gen10 Plus E-2224 for a small business, and want to add as much disk space as possible. I already have the older Gen10 with 4x4TB HDDs in RAID10 (effective capacity 8TB) and a 2TB SSD in the 5th slot (which is missing on the new G10 plus). The max stated capacity on the HPE site seems to be limited with their own enterprise HDDs, so I'd like to see if I can go for bigger disks. The server would be running a sort of an application which collects lots of data from devices, and the data tends to grow over time (1-2TB per year), and I'd prefer not to worry about the capacity for the next several years.
      My primary concern is the max capacity (max single drive capacity + max total RAID capacity with the Smart Array S100i) I can reliably install. If possible, some actual setup which has been shown to work with 32GB RAM and its limited 180W power supply? I was also planning on upgrading it to 32GB. If I am buying a 16GB RAM server, does this means it has both slots occupied with 8GB modules and I need a 2x32GB kit? For the os SSD, I won't have the PCIe slot available because we need to insert a certain GPS PCIe card that the server uses for time synchronization. So, if I want an SSD, this means I should use something like 1xSSD + 3xHDD in RAID5, instead of RAID10?
      I've been planning to install 16TB Seagate Exos X16 drives, with rated max operating power at 10W (6.3W for random reads/writes). Does this seam feasible?
      Thanks a lot for your tips!
