Single odd RAID 0 SSD, why is fan at 20%
TomP
Just about finished installing and ILO says fan is at 20% with only the SSD fitted. Any ideas why ?
Also I've seen folks mention an ILO remote console, so what is it and where can I get it?
Edited by TomP
I assume you set BIOS cooling profile to optimal?  19-29% would be pretty good for intermediate profile.
The cover needs to be on for proper air flow and cooling and the PCIe slot is in a area without good air flow even with the cover on so that will drive some temps up that drives up the fan speed.
Fan speeds will not settle down till the OS is loaded fully and it's more or less steady state.
I have the stock 1610T CPU and the BIOS setting is 'Balanced Power & Performance' - I don't see any 'Optimal' setting. Other options offered are 'Minimum Power Usage' , 'Maximum Performance' and 'Custom' so which should I use?
My PCie card is tiny, half height and 2-3in deep with (currently no internal cable) so surely this would have little effect? It didn't in my N40L
I fitted the cover and it is now down to 13% (inlet temperature 23C) with OS loaded but I see mention of speeds mentioned here down to as low as 6%.
In BIOS under ADVANCED OPTIONS => THERMAL CONFIGURATION => there are three options: OPTIMAL, INCREASED,& MAXIMUM cooling
https://youtu.be/uH9WLhDMyJU
Check out the links in CSKenney's Links Page => under GEn8 Temperature Management => there's a thread "A Collection of Temp Studies" http://homeservershow.com/forums/index.php?/topic/6762-anyone-who-has-changed-the-heat-sink-on-a-gen8-microserver/page-3#entry77590
With optimal cooling set in BIOS you will also need the 6/6/2014 BIOS update (its a FTP site -- see Gen8 Links page) plus the latest IP UPdate -- that should give you the lowest fan speed (unless I forgot something here :) ) but you may not like the temps on your internal items.
Edited by Joe_Miner
From what I have observed, fan speed increases from 6% proportionally to the amount over 20c that the inlet temperature is.
