Replacement PSU for MS Gen 8 (UK)
Danjor
  • 4 months later...
Do these PSU upgrades require any modification or are they a straight swap for the default/stock PSU?
Are there any effects to the fans etc?
  • 5 months later...
Hello, I would be interested in making an upgrade of the power source since the one that brings 150w I find that it is very fair for what one installs, I was seeing that the Seasonic SS-250SU is to arrive and mount ... some review of this source to be able buy and improve the upgrade of the equipment since I currently have 4 4tb 3.5 disks and 6 2.5 disks installed, so I would like to improve
On 4/26/2018 at 12:42 AM, leto said:
Compañeros. Quiero confirmar que  Seasonic SS-250SU funciona perfectamente con Microserver Gen8. La primera fuente de alimentación SS-250SU que recibí estaba simplemente defectuosa y tuve que pedir otra exactamente igual para probar y confirmar que funciona.
Buenas noticias y estoy muy feliz ya que ahora puedo ejecutar mis flujos de trabajo de flujo tensorial en mi tarjeta de perfil bajo Gigabyte Nvidia GTX 1050ti modificada que cambié para tomar solo una ranura evitando cortar un orificio adicional en la placa posterior gen8. :)
Tengo 5 discos duros de 3,5 pulgadas + Gigabyte GTX 1050ti + Xeon E3-1270 V2 + 16Gb RAM. Es una pequeña bestia.
Salud
Hi.
You know I want to buy the same font as you install. How has it worked for you is to arrive and install or do you have to make any changes?
    • Haxsource
      By Haxsource
      Good afternoon folks!
      I have a question I was wondering if someone would know about. I have a Microserver Gen 8 with Vmware ESXI 7 currently installed on the MicroSD with AHCI enabled instead of RAID mode (dont find anything usefull in raid mode in my current setup other than booting from ODD, which I can just use as another Datastore instead).
      With that context being said, Im trying to enable the Agentless Management Service from the ILO with the drivers on the Vmware ESXI 7, but unfortunetly after installing and trying to start the service with:
      /etc/init.d/hp-ams.sh start
      I get the following error:
      /opt/hpe/ams/amshelper: error while loading shared libraries: libnicmgmt.so.0: cannot open shared object file: No such file or directory
      Makes sense following the Vmware ESXI HPE support matrix, since its only supported until Vmware ESXI 6.5U2 Pre-gen. But I´ve been reading lots of people having working setups doing the following:
      Install Vmware ESXI HP Custom Image 6.5U2 -> Offline Update to Vmware ESXI 6.7.
      I was wondering if installing HP Custom Image 6.5U2 with the drivers Agentless Management Service working and doing a full upgrade to ESXI 7.0 would do the trick, since its an upgrade not a clean install...so libraries should stay supporting older drivers installed.
      Does this make any sense?? Has anyone gone trough this alredy?
      Thanks!
    • netware5
      By netware5
      ***CRITICAL*** iLO 4 update available here. HPE requires users update to this version immediately. Potential vulnerabilities in network stack.
      VULNERABILITY SUMMARY
      A potential security vulnerability has been identified in Integrated Lights-Out 5 (iLO 5), Integrated Lights-Out 4 (iLO 4), and Integrated Lights-Out 3 (iLO 3) firmware. The vulnerability could be remotely exploited to cause memory corruption.
      HPE has released updated firmware to mitigate these vulnerabilities.
      References: CVE-2020-27337
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • gru
      By gru
      Hi! I am planning to buy a Microserver Gen10 Plus E-2224 for a small business, and want to add as much disk space as possible. I already have the older Gen10 with 4x4TB HDDs in RAID10 (effective capacity 8TB) and a 2TB SSD in the 5th slot (which is missing on the new G10 plus). The max stated capacity on the HPE site seems to be limited with their own enterprise HDDs, so I'd like to see if I can go for bigger disks. The server would be running a sort of an application which collects lots of data from devices, and the data tends to grow over time (1-2TB per year), and I'd prefer not to worry about the capacity for the next several years.
      My primary concern is the max capacity (max single drive capacity + max total RAID capacity with the Smart Array S100i) I can reliably install. If possible, some actual setup which has been shown to work with 32GB RAM and its limited 180W power supply? I was also planning on upgrading it to 32GB. If I am buying a 16GB RAM server, does this means it has both slots occupied with 8GB modules and I need a 2x32GB kit? For the os SSD, I won't have the PCIe slot available because we need to insert a certain GPS PCIe card that the server uses for time synchronization. So, if I want an SSD, this means I should use something like 1xSSD + 3xHDD in RAID5, instead of RAID10?
      I've been planning to install 16TB Seagate Exos X16 drives, with rated max operating power at 10W (6.3W for random reads/writes). Does this seam feasible?
      Thanks a lot for your tips!
