Replacement PSU for MS Gen 8 (UK)
Danjor
  • 8 months later...
  • 2 years later...
Hi Guys. Since you upgraded your Microserver Gen 8 PSUs, I wonder if you can help. I purchased this PSU
https://www.newegg.com/Product/Product.aspx?Item=17-151-142&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=11552995&PID=5334937&SID=17214X742339Xc597319d271bcdcb16a174d179346859
and although iLo works the server turns off immediately when the power button is pressed with a message in the logs saying System Power Fault Detected. I looked an the wires in the original 150W PSU 24 pin connector and Seasonic 24 pin connector and there are a couple of differences. I'm not sure but I assume that Seasonic has standard ATX 24 pin wiring. There is a small chance I may have purchased a faulty PSU but wonder if any of you have ever had any problems with replacement PSUs and how you solved it? Maybe there is some non-standard wiring on HP Microserver...?
Basically the question is if anyone successfully upgraded the power supply in their Microserver Gen8 to some PSU with more Wattage say 250W / 300W and if yes which PSU was used? If you have pictures would be amazing.
I actually got a message from fury who uses FSP250-50GUB in Microserver Gen8. I looked at this PSU and it looks like the fan sits on the inside. So not sure if it's pulling air from outside into Gen8 or pushes it out. Would be not that great if it's pulling air in..
I checked the Dutch forum and yes, it looks like one person is using Seasonic SS-250SU in his Micro Gen8. I recently bought same PSU and it only powers iLO and gives PSU fault message on the server startup and server shuts down immediately. I also checked with my friend who said that often HPs and Compaq have non-standard 24pin wiring. Maybe the used Seasonic PSU I bought is the lemon but it would suck if I buy another one and face same problem.
I looked at the picture in the Dutch forum and wire coloring is same as on my Seasonic. (pic attached)
Would be nice if someone has the pinout diagram for Microserver Gen8 24pin connector? Wonder if it's a standard ATX pinout. Look at the Microserver standard power connector (pic attached below). Looks like a couple of things are different..
So would be great to know what PSUs definitely work..
Mates. I want to confirm that Seasonic SS-250SU works perfectly with Microserver Gen8. The first SS-250SU power supply I received was simply faulty and I had to order another same exact one to test and confirm that it works.
So great news and I'm super happy since now I can run my tensor flow workflows on my moded Gigabyte Nvidia GTX 1050ti low profile card that I changed to take only one slot avoiding cutting an extra hole in the gen8 back plate. :)
I have 5  3.5 inch hard drives in it +  Gigabyte GTX 1050ti +  Xeon E3-1270 V2 + 16Gb RAM. It's a small beast.
Cheers
Cheers
so, as i can see u only have graphic card in your pci-e slot? you are using your gen8 unit without any hba/raid card? are your 5 hdd-drives connected to the onboard B120i?  just currious to know
Edited by ari2asem
  • 1 year later...
As I am running the GTX1050Ti and Xeon 1240 v2 I have done the PSU upgrade too, as commented by others the Seasonic 250W is an easy fit, 10m
    • Haxsource
      By Haxsource
      Good afternoon folks!
      I have a question I was wondering if someone would know about. I have a Microserver Gen 8 with Vmware ESXI 7 currently installed on the MicroSD with AHCI enabled instead of RAID mode (dont find anything usefull in raid mode in my current setup other than booting from ODD, which I can just use as another Datastore instead).
      With that context being said, Im trying to enable the Agentless Management Service from the ILO with the drivers on the Vmware ESXI 7, but unfortunetly after installing and trying to start the service with:
      /etc/init.d/hp-ams.sh start
      I get the following error:
      /opt/hpe/ams/amshelper: error while loading shared libraries: libnicmgmt.so.0: cannot open shared object file: No such file or directory
      Makes sense following the Vmware ESXI HPE support matrix, since its only supported until Vmware ESXI 6.5U2 Pre-gen. But I´ve been reading lots of people having working setups doing the following:
      Install Vmware ESXI HP Custom Image 6.5U2 -> Offline Update to Vmware ESXI 6.7.
      I was wondering if installing HP Custom Image 6.5U2 with the drivers Agentless Management Service working and doing a full upgrade to ESXI 7.0 would do the trick, since its an upgrade not a clean install...so libraries should stay supporting older drivers installed.
      Does this make any sense?? Has anyone gone trough this alredy?
      Thanks!
    • netware5
      By netware5
      ***CRITICAL*** iLO 4 update available here. HPE requires users update to this version immediately. Potential vulnerabilities in network stack.
      VULNERABILITY SUMMARY
      A potential security vulnerability has been identified in Integrated Lights-Out 5 (iLO 5), Integrated Lights-Out 4 (iLO 4), and Integrated Lights-Out 3 (iLO 3) firmware. The vulnerability could be remotely exploited to cause memory corruption.
      HPE has released updated firmware to mitigate these vulnerabilities.
      References: CVE-2020-27337
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • gru
      By gru
      Hi! I am planning to buy a Microserver Gen10 Plus E-2224 for a small business, and want to add as much disk space as possible. I already have the older Gen10 with 4x4TB HDDs in RAID10 (effective capacity 8TB) and a 2TB SSD in the 5th slot (which is missing on the new G10 plus). The max stated capacity on the HPE site seems to be limited with their own enterprise HDDs, so I'd like to see if I can go for bigger disks. The server would be running a sort of an application which collects lots of data from devices, and the data tends to grow over time (1-2TB per year), and I'd prefer not to worry about the capacity for the next several years.
      My primary concern is the max capacity (max single drive capacity + max total RAID capacity with the Smart Array S100i) I can reliably install. If possible, some actual setup which has been shown to work with 32GB RAM and its limited 180W power supply? I was also planning on upgrading it to 32GB. If I am buying a 16GB RAM server, does this means it has both slots occupied with 8GB modules and I need a 2x32GB kit? For the os SSD, I won't have the PCIe slot available because we need to insert a certain GPS PCIe card that the server uses for time synchronization. So, if I want an SSD, this means I should use something like 1xSSD + 3xHDD in RAID5, instead of RAID10?
      I've been planning to install 16TB Seagate Exos X16 drives, with rated max operating power at 10W (6.3W for random reads/writes). Does this seam feasible?
      Thanks a lot for your tips!
