USCMitch Posted June 25, 2015 Share Posted June 25, 2015 Greetings all- I'm in the midst of upgrading my server and need some advice on the choice of CPU. Current configuration: MOBO: Asus P8H77-I CPU: i5-3570K RAM: 8GB OS Drive: 500GB WD Blue Storage: 4x2TB WD Red Upgrading to: MOBO: Gigabyte Z97N-IWifi RAM: 16GB OS Drive: Samsung 850 Evo 250GB Storage: 4x2TB WD Red + 2x4TB Red Primary uses: Backup of 3 PCs, streaming locally stored media, occasional transcoding of media. - Minimize power usage, heat, etc. - Ensure that there is plenty of capacity available to account for future expansion, etc. - Avoid overspending Have been looking at the following CPUs: -i5-4690S -i5-4690T -i7-4790T -i3-4370 I've gone round and round trying to determine which CPU strikes the right balance between price, performance, and low power consumption. I'd love to hear some outside thoughts, opinions, and suggestions. If there is another option that I've not considered, please share. Thanks in advance. Link to comment Share on other sites More sharing options...
Jason Posted June 25, 2015 Share Posted June 25, 2015 I have same CPU with 32 GB RAM and have found no reason to upgrade Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
USCMitch Posted June 26, 2015 Author Share Posted June 26, 2015 Nor am I having any issues. However, I'm repurposing the mobo and CPU currently in the server and decided it would be a good time to upgrade the hardware. Essentially, I'm looking for advice as to what would be the best CPU if the goals are serving media and files, backing up local clients, run as cool and low powered as possible yet preserve the ability to transcode media in the future if needed. Thanks for responding. Link to comment Share on other sites More sharing options...
Joe_Miner Posted June 26, 2015 Share Posted June 26, 2015 For future flexibility I would look ar the 4690 & 4690K and maybe the 4790 & 4790K comparing the benchmarks for all Link to comment Share on other sites More sharing options...
USCMitch Posted June 26, 2015 Author Share Posted June 26, 2015 Should I consider their low power variants or only the standard and unlocked variants? Thanks. Link to comment Share on other sites More sharing options...
Joe_Miner Posted June 26, 2015 Share Posted June 26, 2015 (edited) With that Z97 System Board you're planning on I'd look at the benchmarks on all (low power, std, unlocked) as well as the specs for each and what OS's you will/may run on it now and in the future. Your desire to build in flexibility now to meet possible future expansion or repurpose is why I would look at what I'm trading off btwn the different CPU's. It may be that the Benchmark performance and specs are close enough that then it's a decision based purely on TDP. You could check PassMarks rankings for insight on that too. Of course, if you're in an area where kWh costs are very high then power requirements considerations may rank a lot higher than long-term flexibility. My Z77 was originally intended to be a VM server but I put an i7-3770 in it to future proof it -- after 2 years I decided to make my Gen8 a VM server and repurpose the Z77 to a desktop that I could run VM's -- my i7 made that an easier decision but YMMV. -- Bit of history: my N54L had been my WHS2011 machine but a family member was interested in it and I was looking to expand the number of Drives in WHS-2011 so I lost the N54L and moved my old desktop, X58, to my WHS-2011 Server, which led to making the Z77 my new desktop. Obviously YMMV -- but I tend to keep and repurpose my computers for a long time so I plan a "little" more flexibility in at the beginning if I can. Edited June 26, 2015 by Joe_Miner Link to comment Share on other sites More sharing options...
