Strange varying copying speeds using b120i controller
colinw
i have two wd red drives 3tb in my gen 8 in the first two drive bays via the b120i controller set as raid 0 individual.
Running windows 8.1.
What I notice is that if I copy any large file from one wd drive to the other the copy speed starts off at a blistering 1gb/sec and then after a few seconds it settles down to 100mb/sec and stays at this speed.
If I do the same the other way round the copy speed is around 145mb/sec constant.
Does anyone know why I get this odd behaviour ?
Thanks in advance.
The 145MB/Sec seems correct as that is the sustained throughput of the Red drives.
So copying drive A to B starts fast and slows. Copying B to A is consistent 145MB/Sec.
Is this true even if you try B to A first?
hi schoondoggy,
it seems after playing some more the constant 145mb/sec is just the first time copy, if i repeat the process again and again it does also start at a very high speed and come down to 145mb/sec.
So the only odd thing now is why one way is 100 and the other is 145 ?
They are the same model drive purchased at the same time etc.
Maybe there is an updated raid controller driver ?
Thanks anyway.
Are you booting from drive A?
Also, the really high rate is probably due to the file already existing and it just starts verifying the file.
It depends on what part of the drive you are saving too
6TB WD
Start of drive 175MB/S End of drive 80MB/S
The 3tb is slower than the 6tb as well
No i'm  booting from the ODD internal sata port.
Ok nice one i did not know the speed can change across the drive.
Thanks both for your help.
