Which driver do I need for Microsd?
psykix
Microsd doesn't show up in Windows. Anyone know what driver I need to install to get it to show up?
I forgot to use IP to do the install this time around!
Cheers!
No driver needed. I've never used it for anything other that booting ESXi though. You may be hitting the annoying bug with it though. If you run IP, SSA or enter setup then it disables the SD reader for some unknown reason. You need to power off + unplug the microserver to fix it. Just a few seconds and plugging it back in should fix it.
Edited by GotNoTime
