MikeJ Posted June 13, 2015 Share Posted June 13, 2015 Hi, I seem to remember seeing some people running their Gen 8 at 1600MHz. Any ideas as to why my Gen 8 runs at 1333MHz - even the original 2GB memory is 1600MHz. Thanks, MikeJ. Link to comment Share on other sites More sharing options...
schoondoggy Posted June 13, 2015 Share Posted June 13, 2015 What CPU do you have? Link to comment Share on other sites More sharing options...
MikeJ Posted June 13, 2015 Author Share Posted June 13, 2015 Intel Celeron G1610T @ 2.3GHz - standard issue on my kit. Link to comment Share on other sites More sharing options...
schoondoggy Posted June 13, 2015 Share Posted June 13, 2015 The G1610T memory bus runs at 1333MHZ: http://ark.intel.com/products/71074/Intel-Celeron-Processor-G1610T-2M-Cache-2_30-GHz Most of the XEON cpu will run at 1600MHZ. HP uses the 1600MHZ memory as the standard. Link to comment Share on other sites More sharing options...
MikeJ Posted June 13, 2015 Author Share Posted June 13, 2015 That would explain it . Thanks. Link to comment Share on other sites More sharing options...
danyxp Posted June 24, 2015 Share Posted June 24, 2015 I have a gen 8 with Intel® Xeon® CPU E3-1220L V2 @ 2.30GHz with 8GB ram and ILO reports the memory at 1333 Mhz part number 647658-081 maximum frequency 1333 MHz operating/maximum voltage 1.5 v Do I have to do something in bios or I was fooled by the vendor ? Link to comment Share on other sites More sharing options...
schoondoggy Posted June 24, 2015 Share Posted June 24, 2015 The memory part number you have listed is 1333: HP 8GB (1x8GB) Dual Rank x8 PC3L-10600E (DDR3-1333) Unbuffered CAS-9 Low Voltage Memory Kit 647909-B21 664696-001 647658-081 For the XEON to run at 1600 the memory would need to support 1600 as well. Link to comment Share on other sites More sharing options...
danyxp Posted June 24, 2015 Share Posted June 24, 2015 where do i see that reported ? right now I only have access to ilo interface and the vsphere client running on a windows vm. Link to comment Share on other sites More sharing options...
schoondoggy Posted June 24, 2015 Share Posted June 24, 2015 I just looked up the part number on HP.com http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c03713800%20647658-081 Link to comment Share on other sites More sharing options...
danyxp Posted June 24, 2015 Share Posted June 24, 2015 (edited) That link shows nothing found Not sure if to return to seller or just by another memory... edit: No poit arguing with the seller, in the invoice apears 8GB at 1333; so I have to be more careful in the future. Also on the website they have the 1333 spec. correctly displayed. Edited June 24, 2015 by danyxp Link to comment Share on other sites More sharing options...
