Home Network IP Address Scheme Best Practice
schoondoggy
itGeeks
Wondering whether I should just be using the DHCP server built into my router instead of Windows DHCP server? What do others here do?
Instead I create a reservation on Windows DHCP, mirror that IP definition in Sophos UTM, then add to a Sophos UTM https exception list. More steps than I probably need?
Unless your doing something fancy that your router does not support then as jmwills said keep it on the router.
Still a work in progress. Home address range 192.168.1.1-255 Lab address range 192.168.2.1-255
Home:
1-20 Networking/Firewall
30-43 PC/Laptop
49-68 Home Automation
100-149 DHCP range
180-185 Printers/Scanners
190-225 Audio/Video/Media/Gaming
235-254 Servers/VM's
Thanks for the info...
  • Replies 63
  • nrf
    10
  • jmwills
    9
  • itGeeks
    9
  • ShadowPeo
    6
Popular Posts
Mine is varied but have used it for 20 years so not changing now 1 router 2 printer 3 main pc After that odds are static pc and evens are device like NAS,ilo,rac, vhost 51-60 ip cam 21-30 networ
I use a mixture - servers and infrastructure get fixed IPs. Since some routers require reserved IPs to fall within its dhcp range and some outside I don't mess with it. I have frequently changed route
I usually group IP Addressing by functionality.  I even go to the extreme of keeping domains within a range.
Posted Images
what is the intended benefit of a complicated addressing scheme? I can see fixed assignments for devices offering services, with a range for 'clients' to be dynamic... even then, my hdhomeruns work just fine with random ip assignments
ShadowPeo
Basically for knowing where things are, and depending on your management practices (for example routing/firewall) you may apply different rules for different ranges. For example at one location I have the server/device range to be allowed straight through the firewall, no authentication, nothing, anything outside that authenticates.
itGeeks
First thing that comes to mind is OCD :D Talking about OCD does anyone else besides me color code there cables? Kidding aside I like my network organized, I know at a glance if something is not rite and doing this allows me better management. I concur with ShadowPeo. On closing its not a complicated habit to get into.
schoondoggy
At home, I think I have finally given up on the color coding rules we had defined for Ethernet cables in IT departments and labs, except Red will always be a crossover cable and Yellow will always be iSCSI traffic.
jmwills
I was waiting for someone to admit to that. :)
ShadowPeo
I use the same colour coding at home as I do for clients. I have not fully got all the clients cleaned up and on standards but that is due to the amount of work needed vs available support hours. Anyway two are complete, and the other two are 80-90% done
My structure is as such - I also post this (or where there is no router, a copy of the page without the router section)
ROUTER LINKS - WORK - This is a managed service we cannot change anything
COLOUR - LINK
BLACK - PUBLIC
ORANGE - DMZ
PURPLE - SECURE
YELLOW - MEDIA CONVERTER/DMZ
ROUTER LINKS - HOME
COLOUR - LINK
RED - LINK FROM NTU
ORANGE - VLAN LINK TO SWITCH
FIBRE PATCHES - Yes I have fibre at home as well
COLOUR - DEVICE
YELLOW - OS1/OS2
AQUA - OM3
SWITCH PATCHES
COLOUR - DEVICE
BLACK - VIDEO DISPLAYS
BLUE - COMPUTERS & DATA
GREEN - WIRELESS ACCESS POINTS
GREY - SERVERS
ORANGE - VOICE CARRIER TIE
PINK - SECURE
PURPLE - PRINTERS
RED - NETWORK DEVICES
WHITE - SECURITY CAMERAS
YELLOW - VOICE PABX TIE
I use random addresses, in the private range but not 192.168.*.*
Static devices will use static IP (again random) and dynamic will use DHCP from Sophos UTM. The static addresses are defined as hosts on Sophos as well, so they appear in the reports correctly.
This is an interesting read: http://routersecurity.org/ipaddresses.php
that article seems a bit shaky, with the exception of the use of permanent site-to-site vpns. one can easily find their own ip and default gateway then there is no mystery.
