Asus E45 M1-M Pro Motherboard
janzy
New, open box unused hard to find micro atx motherboard with embedded cpu. HiDef graphics built in.
Great board for a server build, such as unRaid or FreeNas.
Also including 2 sticks of ddr3 ram, each stick is 2gb
$80 plus shipping
Specs:
Model Number : N50 > N50-AS031CN50-123456N50-234567
  • CPU
    AMD APU E-450 Dual-Core onboard Processors
    Supports AMD® Turbo Core Technology
  • Chipset
    AMD FCH A50M (Hudson M1)
  • Memory
    2 x DIMM, Max. 8GB, DDR3 1600(O.C.)/1333/1066 MHz Non-ECC, Un-buffered Memory
    Single Channel Memory Architecture
    * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
    * Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Install a 64-bit Windows® OS when you want to install 4GB or more memory on the motherboard.
  • System Bus
    Up to 2.5 GT/s UMI Link
  • Graphic
    Integrated ATI Radeon™ HD 6320 GPU
    Multi-VGA output support : HDMI/DVI/RGB ports
    - Supports HDMI with max. resolution 1920 x 1080 @ 60 Hz
    - Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
    - Supports RGB with max. resolution 2560 x 1600 @ 60 Hz
    Supports DirectX 11
  • Expansion Slots
    1 x PCIe 2.0 x16 (x4 mode)
    1 x PCIe 2.0 x1
    2 x PCI
  • Storage
    Built-in Controller :
    5 x SATA 6Gb/s port(s), white
    1 x eSATA 6Gb/s port(s), red
  • LAN
    Realtek®, 1 x Gigabit LAN Controller(s)
  • Audio
    Realtek® ALC887 8-Channel High Definition Audio CODEC *1
    - Supports : Multi-streaming, Front Panel Jack-retasking, Anti-pop Function
    Audio Feature :
    - Optical S/PDIF out port(s) at back panel
  • USB Ports
    ASMedia® USB 3.0 controller :
    2 x USB 3.0 port(s) (2 at back panel, blue)
    12 x USB 2.0 port(s) (4 at back panel, black+red, 8 at mid-board)
  • Special Features
    ASUS EPU :
    - EPU
    ASUS Protect 3.0 Technology :
    - Anti-Surge Protection
    - Low EMI Solution
    Turbo Key
    Turbo Key II
    TurboV
    ASUS Exclusive Features :
    - AI Suite II
    - Ai Charger+
    - ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
    ASUS Quiet Thermal Solution :
    - ASUS Fan Xpert
    ASUS EZ DIY :
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 2
    - ASUS MyLogo 2
  • Back I/O Ports
    1 x PS/2 keyboard/mouse combo port(s)
    1 x DVI
    1 x D-Sub
    1 x HDMI
    1 x eSATA 6Gb/s
    1 x IEEE 1394a
    1 x LAN (RJ45) port(s)
    2 x USB 3.0
    4 x USB 2.0
    1 x Optical S/PDIF out
    3 x Audio jack(s)
  • Internal I/O Ports
    4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
    1 x COM port(s) connector(s)
    5 x SATA 6Gb/s connector(s)
    1 x IEEE 1394a connector(s)
    1 x CPU Fan connector(s)
    1 x Chassis Fan connector(s)
    1 x S/PDIF out header(s)
    1 x 24-pin EATX Power connector(s)
    1 x 4-pin ATX 12V Power connector(s)
    1 x parallel port connector(s)
    1 x Front panel audio connector(s) (AAFP)
    1 x System panel(s)
    1 x Turbo Key II switch(es)
  • Accessories
    User's manual
    I/O Shield
    2 x SATA 6Gb/s cable(s)
    1 x CPU FAN
  • BIOS
    32 Mb Flash ROM, UEFI BIOS, PnP, DMI 2.0, WfM 2.0, ACPI 2.0a, SM BIOS 2.6
  • Support Disc
    Drivers
    ASUS PC Probe II
    ASUS Update
    Anti-virus software (OEM version)
