Anyone have a source for replacement Hard Drive Caddy Screws
gcc
The head diameter looks good, but I do not see a spec for the angle of the head. It should be 100 or higher.
Standard ANSI screws do have a 82 degree included angle on the countersink
You have to specifically search for
"6-32 100 degree countersunk flat head screws"
and who is able to ship in less than bulk quantities to your location
Length may be an issue. You may be able use a slightly longer bolt, or can carefully cut to lenght using a cut off wheel on a dremel
I once had to buy 600 4mm bolts to replace 2 bolts on a piece of equipment at work. 300 bucks !
  • Haha 1
