Marvell 9230 Firmware Updates and such
Shonk
How to remove old driver backup's
Microsoft Windows [Version 10.0.10240]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>pnputil -e
Microsoft PnP Utility
Published name :            oem8.inf
Driver package provider :   Marvell Semiconductor Inc.
Class :                     System devices
Driver date and version :   09/05/2013 1.2.0.1039
Signer name :               Microsoft Windows Hardware Compatibility Publisher
Published name :            oem21.inf
Driver date and version :   04/30/2015 1.2.0.1047
Published name :            oem23.inf
Driver date and version :   05/05/2015 1.2.0.1047
Published name :            oem2.inf
Driver date and version :   09/03/2014 1.2.0.1045
Published name :            oem10.inf
Driver package provider :   Marvell Inc.
Class :                     Storage controllers
Published name :            oem22.inf
Published name :            oem19.inf
So in my case (this is unique per machine)
i have to do the following
pnputil.exe -d Oem8.inf
pnputil.exe -d Oem21.inf
pnputil.exe -d Oem2.inf
pnputil.exe -d Oem10.inf
pnputil.exe -d Oem19.inf
Hello,
Like I write it, I only have the A1 version of the 2.3.0.1058 firmware.
I dump the firmware of  card I just bought, and it's a A1 chipset.
Rck
Damn, that's ashame. I remember now you wrote it. Do you know a source on the internet where to get it? I've searched a lot and I can't find it.
Marvell 1.2.0.1047 (05-05-15)
http://pc.cd/knFrtalK
Dont forget to update the Marvell Console
Thanks mate but I've tryed to download the archive and both links told me "the archive is damaged and could not be read". By the updating the console, would mean to get the earlier version of MVU?
Edit : I've downloaded the 1047 version here instead : http://www.station-drivers.com/index.php?option=com_remository&Itemid=352&func=startdown&id=1570
Edited by Jason BOURNE
Marvell MSU 4.1.0.2027
http://pc.cd/2sFrtalK
- Version: 4.1.0.2027
- Date Release: 2014/07/08
Item    Description                                                   Related Bug Ticket
1.    Fix issue #7149: Rescan MSU when connect Expander with SAS devices, the number of adapter will add one
- Version: 4.1.0.2026
- Date Release: 2014/07/04
- Author: Flag
- Changes:Flag
1.    support new firmware image format
- Version: 4.1.0.2025
- Date Release: 2014/06/30
1.    Fix handles number increase in task manager issue.                   #7426
2.    Fix 9580 can not been found issue
- Version: 4.1.0.2024
- Date Release: 2014/06/12
1.    add API protection code.
2.    disable https in MSU.
3.    update Apache to 2.2.27 and PHP to 5.4.28.
4.    add member disk list in disk array information.
5.    fix device id format when update fw.
6.    add hd count limit in quick create.             #6851
Edited by Shonk
- Author: Flag
- Changes:Flag
Thx Shonk I just updated my winrar my "whole marvell set" as the silly lazzy guy I am. Before I tried your combination and bigrck's one (drivers/firmware/MSU) hoping it will allow me to run at 5.0Gbps but I'm still stuck at 2.5 and I lost trim ability. I guess the rev A0 is a bit sh*tty. Here's all information reported on MSU. If you got any suggestions to raise the 5.0 Gbps it would be very helpfull from you. By the way, there's not that much topics about this controller on the internet, so thanks for your help, I really appreciate.
If it helps here's my conf's specs:
Asus Striker II Extreme
QX9770
2 x 4 Go Corsair Vengeance
Asus GTX 780 DCUII OC SLI
Xfi Titanium HD
Intel 530 series 240 Go as System SSD on Syba SD-PEX40054
Seagate sv35 3to as Data HDD on Syba SD-PEX40054
G19
Func MS-3 rev 1
Enermax Galaxy Dx 1Kw
2 x combo bluray drives on Mobo
Asus VG278H
I guess I've forgotten nothing...
You are running 2.3.0.1063 firmware
its locked at sata gen1
roll back to 2.3.0.1055 A0
thats the latest A0 firmware revision thats not borked
also the card needs to be in one of the blue 16x slots
they are the only pcie rev2 slots on your board
Edited by Shonk
Thanks for the advice.
I can't plug it on blue slots, both are taken by my GPU cause I'm in SLI. Instead I use the PCIe 4x. So bye bye the 5.0Gbps.
Here are my current performances :
How do you find this? Do you have other test you want me to make? Your advice interests me.
the white slot is pcie revision 1
put one of the gpu's in the 16x r1 slot thats fine for a gpu
Edited by Shonk
