Marvell 9230 Firmware Updates and such
Shonk
Thnx for the info.
I've got major issues with this controller runnig Fedora Linux, trying to find new fw for it.
Although my hardware isn't a Gen8 server.
Today I received the same files Asrock provides from Supermicro, for my X10SBA, hopefully they'll solve my 9230 issue.
  • 4 weeks later...
Hello Shonk.
I work a lot those days to have the best driver & firmware of my Marvell 9230 sata PCIe 2x card,
Here are my files :)
  1. Driver 1.2.0.1032 - because it's the last with TRIM support (controlled with Trimcheck 0.7)
  2. Firmware 2.3.0.1058 - A1 chip only - because it's the last with PCIe 2x support (5.0Gbps - controlled with MSU)
  3. MSU 4.1.0.2023 - lastest available.
Newer Marvell Drivers give one extra boost to Read & Write Sequential access, but lack of TRIM is a no go in long term performance !
I tested the following drivers:
  • Previous Drivers - Doesn't work with the 9230
  • Driver - 1.2.0.1027 (trim OK)
  • Driver - 1.2.0.1032 (trim OK)
  • Driver - 1.2.0.1038 (no trim)
  • Driver - 1.2.0.1039 (no trim)
  • Driver - 1.2.0.1041 (no trim)
  • Driver - 1.2.0.1045 (no trim)
  • Firmware - 2.3.0.1058 (PCIe2x OK)
  • Firmware - 2.3.0.1063 (no PCIe2x)
Let's hope a few people will find this post usefull  :)
My best config:
Edited by bigrck
I dont use an ssd on the marvell
but people have been saying 1.2.0.1045 trim works fine
thanks for the 2.3.0.1058 firmware where did you get it?
Edited by Shonk
I have looked through the code for the firmware
2.3.0.1051 = May 17 2013 Marvell (5.0Gbps x2)
2.3.0.1055 = Oct  8 2013 Marvell (5.0Gbps x2)
2.3.0.1058 = May  2 2014 Marvell (5.0Gbps x2)
2.3.0.1063 = Oct 15 2014 Marvell (2.5Gbps x2) (Asrock Disabled the hardware raid on on this firmware btw) (for some reason it still runs at 5.0Gbps x2 on Asrock Boards see image)
Edited by Shonk
