Marvell 9230 Firmware Updates and such
Shonk
As People have shown an interest how to do this in the past here's how its done
This is my factory backup of the spi chip from my Syba SI-PEX40058 (Marvell 9230 Revision A1)
Syba for some reason dont supply firmware updates
but update the firmware on products being shipped
My goal is to get a database of original spi backup's for the SI-PEX40058
so people can update
I will start with mine for people on older revisions
If yours is newer or even older plz upload a copy for people
My backup (ORIG.BIN)
AUTOLOAD VERSION[0x00000000]: 200017
LOADER VERSION[0x0000C000]: 21001005
BIOS VERSION[0x00020000]: 1.0.0.1016
FIRMWARE VERSION[0x00030000]: 2.3.0.1051
BIOS Version 1.0.0.1017
Firmware Version 2.3.0.1051
Boot Loader Version 2.1.0.1005
this has to be done via a usb stick in dos
do a complete spi image backup (do this first)
go -ra
to use my image
cd bin
MVF_MAG.EXE ORIG.BIN -newImag
to go back to your old image
cd bin
MVF_MAG.EXE BKIMG0.BIN -newImag
This also has a copy of the beta firmware sourced from Stationdrivers
AUTOLOAD VERSION[0x00000000]: 200018
BIOS VERSION[0x00020000]: 1.0.0.1019
FIRMWARE VERSION[0x00030000]: 2.3.0.1055
BIOS Version 1.0.0.1018
Firmware Version 2.3.0.1055
if you wish to try it
just type go
SPI Backup 2.3.0.1051
http://pc.cd/bIb7
Latest Drivers 1.2.0.1045 Sept 2014
http://pc.cd/RIb7
Edited by Shonk
There's a new Marvell 9230 firmware from an unknown source
Be warned it dropped my card from 5.0Gbps x2 to 2.5Gbps x2
So make sure you have a backup
PACKAGE VERSION[0xFFFFFFFF]: 2.3.0.1061
LOADER VERSION[0x0000C000]: 21001008
BIOS VERSION[0x00020000]: 1.0.0.1024
FIRMWARE VERSION[0x00030000]: 2.3.0.1063
http://pc.cd/Gve
Latest Marvell MSU 4.1.0.2033
http://pc.cd/8Ib7
Oh the beta firmware from stationdrivers that i included with my spi backup looks like so
another thing worth pointing out sometimes after a spi flash
the ilo sd card will fail to enumarate in windows for some reason
this is a hp bug and the only way to fix it is a full power down and unplug
e.g. not just power down but remove the electricity also for 10 secs
Edited by Shonk
I Forgot to say there are two revisions of the chipset A0 and A1
My backup is only for revision A1
Also i have found a way of fixing the sd card failing to enumerate in windows after a spi flash
Cold Boot in iLO
It looks like Syba are just using the reference design for this card and shipping the stock Marvell 88SE9230 firmware. The VID/PID is the normal one for Marvell and the 88SE9230. I expect that the A0 revision chip is fine with your A1 revision firmware but obviously do this at your own risk etc...
If you use Google to search for "marvell 9230 firmware" then the first link is another forum that has
BIOS VERSION[0x00020000]: 1.0.0.1015
FIRMWARE VERSION[0x00030000]: 2.3.0.1050
Not sure if i would chance flashing A1 to an A0 chipset
most wll be A1 though ofc due to being the newer revision
the stock marvell flasher comes with two images
ImageA0.bin & ImageA1.bin
so there's differences somewhere most prob down to erata fixes on the A0 silicon
  • 1 month later...
I forgot to update the post
it did indeed come from asrock
though its locked at pci-e gen1 so a bit useless
I have been using this one for the past few months with zero problems
at PCI-E 5.0Gbps x2
