ersen.o Posted April 6, 2015 Share Posted April 6, 2015 as above is there anyway i can use my lan and my iphone connection to download using download station on DSM? Link to comment Share on other sites More sharing options...
oj88 Posted April 6, 2015 Share Posted April 6, 2015 Since this is a Gen 8 Microserver sub-forum, I would assume that you're using XPEnology to run DSM on the G8? Simplest I can think of is to attach a "supported" WiFi dongle on your DSM and connect it to your phone through its WiFi hotspot feature. I haven't tried this and since this is not an official DSM hardware, I don't know if any run of the mill WiFi dongle will work (hence the quotes). EDIT: I tried two generic Wireless-N USB dongles just now on a G7 N40L XPEnology/DSM hack that I built. No dice. Even with either dongles inserted, in Control Panel>Connectivity>Wireless>Wi-Fi tab, it still says "Please insert a USB Wi-Fi adapter". Either a supported dongle exists, or the XPEnology wizards still needs to work on a proper driver. The less elegant way is to connect a LAN cable from the DSM to an extra Access Point or Wireless Router that's configured as a WiFi Client. In Client mode, it should be able to connect to your iPhone's hotspot network. 1 Link to comment Share on other sites More sharing options...
