USB Power Warning
Shonk
I have heard that you can pull upto 2A from a usb port if there's no data connection
Anyway today i added a powered 4 port usb3 hub and some usb drives
USB 3 Hub into USB 3 Port on the Microserver
It comes with a USB power cable to pull extra power which was plugged into a spare USB 2 Port on the microserver
USB 3 Drive 1 = Straight Into port on back of microserver
USB 3 Drive 2 = HUB
USB 3 Drive 3 = HUB
64GB USB 3 Stick = HUB
I started off with 2 drives in the hub and a usb stick which worked fine
having a spare port left on the hub i plugged another usb stick in
thats where the problems started
One of the drives clearly wasnt getting enough power
and was load cycling the heads
196000 Load Cycle Retry's in smart data
1 Reallocated sector
Im hoping the drive isnt actually damaged im moving all the data off it atm and going to secure erase it
which should verify the Reallocated sector
anyway i used this in the end from my HP Touchpad
Its a 2amp USB Power Plug all is fine now..
So the moral of the story is dont try powering 4 devices and a hub from the microserver usb ports :o
http://s5.postimg.org/5strwrzmf/Untitled.jpg
http://s5.postimg.org/w2eufkljr/View_Image_aspx.jpg
http://s5.postimg.org/z2hwqvspj/hub.jpg
I know it supplies 500ma but you can pull more if there's no data connection
on alot of motherboards
My desktop i pull 900ma to charge my phone from a usb 2 port
clearly whatever the hub was pulling wasnt enough
I picked it up knowing if it didnt work i could use the 2amp HP TouchPad power adapter i have
and was expecting it to work or not via internal power
Wasnt expecting one of the drives to have a fit over power
anyway its secure erasing atm (has been the last hour)
hopefully its ok
I just thought i should post about it so someone else doesnt make the same mistake
Edited by Shonk
It appears that it may be possible to get more than the standard 500mA current from a USB2 port if the PC manufacturer has included a charging downstream USB port.  These ports (when used with devices that include the USB Battery Charging Specification) can draw more current from a USB 2 port for charging.  The article I read says that most manufacturers put a lightning bolt beside the higher-amperage USB ports.
Edit - The Dell laptop I use for work has one of these higher-amperage ports and I didn't know it until I was doing the reading for this reply.
That being said I think you have 2 issues.
1. I don't think the Gen8 has a lightning bolt on any of the USB ports (I can't confirm this) so there may not be any higher-amperage ports on this box
2. You were trying to power a hub and not charge a battery.  The higher amperage appears to be designated for charging and requires a device with the USB Battery Charging specification.  Older devices (the article said) that don't have the battery charging specification will be limited to 500mA.
I incorrectly presumed hp would use the same voltage rails as used on the usb 3 ports so would be fine pulling over 500ma
Gigabyte have been doing this for years  as have asrock
I have some 2008 ish motherboards that supply upto 2 amps for all ports
with no indication on the board apart from in the manual
or it may well be that it was pulling 900ma from the port but that still wasnt enough
there's no way to tell without testing the ports
It managed to power 2 drives and one usb stick and the hub
with no problems so it didnt do too bad
it was worth a shot
Edited by Shonk
I think i got lucky
On power down the 196000 load cycle retry's changed to 3 for some reason
One sector is still reallocated i dont think there's any way to force the drive to retest the sector its most prob fine though
I did a Secure erase then an enhanced Secure erase no new smart errors
though the load cycle count has gone up from yesterdays 16000 odd to 17000 odd
Umm on looking into this more i havnt actually got a sector marked off as bad
5,Reallocated Sectors Count 0
196,Reallocation Event Count 1
This is someone's explanation of Reallocation Event Count
The reallocation event count increases in all attempts when the drive starts the reallocation procedure. This includes all attempts when the reallocation does not complete because of a device error or when the drive finds that the reallocation is not required as the sector currently seems usable. I mean that during the reallocation the drive tries to copy all data from the problematic sector to the spare area (usually by special methods and by slower speed) and it is possible that during this, the sector seems perfect - and the drive cancels the reallocation.
