Fiber Uplink Question
CablDeViL
  • Replies 36
  • CablDeViL
    15
  • schoondoggy
    12
    5
  • Drashna Jaelre
    2
Popular Posts
One other option would be get 2 HP V1910 switches you can then make a bundled trunkline using copper even instead of fiber with 2-4 of the ports to give you better bandwidth on the trunk.  better Cisc
When you get it, use the serial number to determine the version and update the firmware: http://support.netgear.com/product/GS748Tv1 Here is a guide to the software. section 4-10: http://www.downlo
schoondoggy
Digikey is a great place to get better fans. This link is already narrowed down to 40 x 10, 5VDC, two wire:
http://www.digikey.com/product-search/en?pv589=16&FV=fff40012%2Cfff80052%2C38007c%2Cb814c4&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
They are rated by sound level as well.
Lower noise usually means lower CFM.
The Copal's at $10 are quiet. The Sunon for $4.31 move more air.
CablDeViL
Fans should be here this week I will get one installed and see how she sounds.  Thank You for the advice / link.
One of my switches did not come with the 2 rack mounts. Should I source the from ebay / amazon or another location.
TY
GotNoTime
Try asking Netgear support. They shipped me a free set of rackmount ears + screws after I explained that I bought the switch from eBay and it was missing them.
