n40l storage questions please help
bilsmaks
im running out of room on my 4x3tb red drives considering upgrading to 4x6tb red drives...id like to think i would be okay doing so....just figured id ask around before spending a chunk on the drives
Also, if there is room, a decent eSATA card should let you run both without any problems
im running xbmc from an ssd im just wondering if the hardware would somehow limit the use of 4x6tb drives im guessing since it took 4x3tb drives okay 6tb drives are just a simple swap and format then load with content?
If the OS/Application could see a 3TB drive it will see a 6TB drive with no problem.  Both are GPT.
The only way I can think of that might make a system not see a 6TB drive is if there was some strange BIOS/UEFI limitation. I can't think why any OEM would do that though.
