What is ILO4?
dikkiedirk
Be sure to check out http://homeservershow.com/forums/index.php?/topic/5639-proliant-microserver-gen8-links/
Lots of possibilities -- check out what others have done in the above links page.  You could use the built-in B120i for RAID1 or RAID10 resiliency and lower fan speeds/lower noise.
WHS2011 runs on it.
Edited by Joe_Miner
Thanks for the advice. If I want raid 5 then I need a P212 or P222?
What is the difference between the the 1610 and 2020 version of this server? As the 2020 version is more than double the price of the 1610 version it must be more than the CPU.
I read somewhere that the 1610 version doesn't have a DVD drive, but is that important? I plan to upgrade the CPU so I might as well get the lowest specced version of this server. But what about memory compatibility. Does it take regular UDIMMs? I still have some Kingston sticks laying around.
The MicroServers can be picky about RAM. Definitely check out the links on the page Joe_Miner linked.
These days, I see no particular reason to have an optical drive.
Well, at the moment I am just starting and I am close to 1 TB of flac, HD flac and ripped SACDs. I think 1 or 2 3TB disks will be enough for the next couple of years.
Have't seen it on ebay yet. For 25 its worth a try.
Search for this key:
512485B21
There is a listing for $24
I got it from work
It conrained ILO Avanced 3Mxxx-Q8xxx-YXxxx-QNxxx-YSxxx
and Insight Control Envr.  3Mxxx-44xxx-S2xxxx-97xxx-8Bxxx
Does that look ok?
