DONARfr Posted March 7, 2015 Share Posted March 7, 2015 Hi, I bought a HP Microserver Gen8 a while ago.In the Micoserver I have 4x2 TB HDDs and one SSD in the ODD slot.After I boot my Server I only get the error: Status: 0xc000000eMy installation steps:1) Create a Raid 0 with the SSD in the ODD Slot2) Install windows Server 2012 R2 with Intelligent Provisioning3) Create an Raid 1+0 with the HDDs4) Initialize the raid with a GPT partion table5) Create a Partition for the data To be sure that I have done no mistake I have deleted the array again and reboot the server after each step.Until step 4 I can boot the server with no problems, but when I create a partition on the raid 1+0 I get the Error 0xc000000e winload.exe is missing.I boot my server with the instructions from TheBiggerMan (http://homeservershow.com/forums/index.php?/topic/5886-gen8-25-hdd-in-the-odd-bay-discussion/?p=67539) If I delete the raid 1+0 array the server is booting again. Has anyone a suggestion to solve the problem? ThanksDONARfr Link to comment Share on other sites More sharing options...
schoondoggy Posted March 7, 2015 Share Posted March 7, 2015 If you are using the B120i and have a single drive RAID0 for the SSD, you do not need to use the procedure you have linked to above. Are you trying to use a microSD card? I would just set up the RAID0 on the SSD and let IP fully install Server 2012 R2 to the SSD. Then I would install the HP array software. Then I would create the RAID10 for the data drives. Link to comment Share on other sites More sharing options...
DONARfr Posted March 8, 2015 Author Share Posted March 8, 2015 Hi, you are right I have a B120i Raid controller. After I removed the USB stick the Server reboots with no error. I don't know why I used the USB stick with a second bootloader, maybe I read too much this forum. Link to comment Share on other sites More sharing options...
