Centos 7 as master OS on Microserver G8. FAQ.
Tmorfuss
Aye, I got the Kingston one saved on my Amazon wishlist :) I was just hoping I'll get by for the first few months with just 4GB...might have been wrong.
  • 3 weeks later...
Hi, I installed CentOS 7.2 successfully with 2 identical 2TB disk in RAID1 by following instructions in this topic, but I came across another issue.
My GEN8 has a very poor disk read performance (25-50MB/s), but the write performance is normal (200MB/s).
Does someone has any idea about what could be happening?
I had the exact same experience with the piece of crap fakeraid b120i.
I've managed to install it in centos 7 using the guide located at: http://josafatisai.blogspot.ro/2016/01/installing-centos-7-on-hp-proliant.html
The upside is that since the driver now correctly reports temperatures, the fan sits at around 6%.
The downside is that I only get speeds of  up to 25MB/s on a raid 0 logical volume, which is outrageous:
[root@centos7 fcmircea]# hdparm -Tt /dev/sdd
/dev/sdd:
 Timing cached reads:   24490 MB in  2.00 seconds = 12263.74 MB/sec
 Timing buffered disk reads:  78 MB in  3.07 seconds =  25.37 MB/sec
For comparison, here is the output from the raid 1 array of two usb 3.0 sticks which hold the centos 7 partitions
[root@centos7 fcmircea]# hdparm -Tt /dev/md0
/dev/md0:
 Timing cached reads:   22038 MB in  2.00 seconds = 11034.31 MB/sec
 Timing buffered disk reads: 114 MB in  3.03 seconds =  37.61 MB/sec
In the end, I went ahead a bought a second hand HP 410i Raid controller from ebay, installed it and just connected the mini sas cable. The logical volumes nedeed no changes. Now here's the output fromt the same raid 0 logical volume:
[root@centos7 fcmircea]# hdparm -Tt /dev/sda
/dev/sda:
 Timing cached reads:   24608 MB in  2.00 seconds = 12323.31 MB/sec
 Timing buffered disk reads: 916 MB in  3.00 seconds = 305.28 MB/sec
The module is still loaded and the controller is still active, but it has no drives. Since it doesn't get a temperature reading, the fan speed has increased to 14% - 19%. But I get proper speeds.
It feels like HP made this specifically difficult in order to gently nudge you to an upgrade. Anyway, a great alternative for people not wanting to buy an additional raid card is to simply switch to AHCI and use linux madam which works very well. I'm not sure about how the fan will react, it might increase speed even more.
I also suspect that on Windows it will work very close to AHCI, perfomance wise. If someone uses B120i with Windows Server, please confirm this.
LE: I went ahead and completely disabled the B120i controller in bios and the fan speed speed has remanied at 14% - 19%. RIP B120i. Also removed the module from the centos kernel.
So, to sum up:
1. Stay away from B120i
2. Get a proper raid card
3. If you don't want to go for 2., set the controller in AHCI mode and use mdadm. Yes, the fan will spin a little faster but performance wise it is well above B120i.
Edited by FCM
  • 2 months later...
So...I've been trying to get CentOS 7 and B120i RAID installed as per various guides here without luck. I got the driver (hpvsa-1.2.14-113.rhel7u2.x86_64.dd), I made bootable USB and when I input "linux modprobe.blacklist=ahci inst.dd" I get the following message: "could not find kernel image linux". I also tried just with "linux dd blacklist=ahci", just to get the same error.
I then tried to just put driver as .dd as well as .img file straight onto USB drive, with the same result.
CentOS version that I'm trying to install is CentOS-7-x86_64-Everything-1511 via USB. My setup is following: SSD drive in the ODD bay, DVD unit on the internal USB port, 2x WD Red HDDs in Port 1 and 2 set up in Raid-1 and 1x Toshiba 2.5" HDD in Port 4.
I tried googling for solutions, I tried different options, nothing seem to work. I read much about Gen8s being great, reliable and cheap, but this has now turned into a three week long nightmare. :/
Any help would be much appreciated.
Edited by Burman
I guess you missed all the posts saying that the B120i is pointless. Use MD RAID or ZFS.
Gordan, would you please elaborate on the ZFS method or provide a link to some sort of manual or thread. Thanks.
Thanks Gordan. After you mentioned using ZFS instead of B120i, I had a bit of a search and found some info, where ppl mentioned if you have an SSD, to set it up as Raid0 and install CentOS on it, then set ZFS raid for other. Do you reckon it is better to go for the option you just gave me the link? Thanks.
Depends. I would advise getting a bit of experience with ZFS before you dive into the deep end and starting using ZFS for your rootfs. But by using ZFS for rootfs, you gain ZFS capabilities for the rootfs (performance impact free snapshots, incremental sends, compression, etc.).
Personally, I use a 4-disk RAIDZ2 ZFS pool for everything on my microservers, and the rootfs is on the same pool.
  • 5 months later...
Hi!
I replaced my n54l to gen8 microserver, and i want to replace winserver 2012r2 to linux based distribution. The poor disk read performance on b120i is general or individual problem under linux.
Thanks!
