Centos 7 as master OS on Microserver G8. FAQ.
Tmorfuss
  • 3 weeks later...
Just want to be sure what's going on here.
Order to store temporary files, which not needed after reboot to RAM, to increase life of SSD drive.
  • 1 month later...
  • 4 weeks later...
Hello everyone.
Install linux firsttime.
I am trying install CentOS7.
Installation ends with error.
Can't understand why this is happening.
Ask for help from the community.
Usb-key with driver and CentOS iso  mount by ILO
Edited by aodalu
are you using the shared iLO port?
Ive seen this before with Intel vPRO - its where the install ISO is disconnected because the OS resets the LAN port.
Try with iLO on its dedicated port.
I use VirtualDriver from ILO Integrated Remote Console.
I have tried to install from usb and dvd, but i get this mistake each time.
I use ACU - raid1 to install os.
The error "dracut-initqueue" disappears when I install via usb and the label usb does not contain spaces. Then I get the error "pane dead" on parse xml tabledatapy.
Edited by aodalu
my steps:
1)burn CentOS-7-x86_64.iso to dvd.
2)rename hpvsa-1.2.10-120.rhel7u0.x86_64.dd to hpvsa-1.2.10-120.rhel7u0.x86_64.img and mount to ILO
3)start HP Microserver
4) on first page press "Esc" and write "linux modprobe.blacklist=ahci inst.dd" press Enter
5) press "1", press "c".
Have error "dracut-initqueue".
blkid show usb /dev/sda: LABEL = "OEMDRV" UUID ="..." type="ext4"
What should i do?
