mgriffiths
What cable required to run 2nd port on P410
Taffeys
Just curious about your 40mm fans.  How did you mount them, and is there really enough room in the top of the case for them to get decent airflow?
The two 40mm fans are Noctua NF-A4x10 FLX (40mmx10mm). I disassembled an old metal 5.25" to 3.5" adapter/cooler I had in my parts bin, replaced the original 40mm "screamer" fans in the front adapter plate with the Noctuas, placed this assembly in the space between the ODD blanking plate and the HDDs, and secured it with bits of double-sided foam tape. Any air flow is better than none. This arrangement doesn't pull any additional air into the case; if it hadn't been effective enough I would have replaced the ODD blanking plate with a screened version but I decided it was not necessary.
ikon
And what temp would that be?
-37F is what it was. It's better right now; only about -8F.
