pfsense build for ~$150
kylejwx
Wish List:
Qty. Product Description Savings Total Price 1 11-128-072-02.jpgARK ITX/CS-Ci02 Black Server Case
Item #: N82E16811128072
Return Policy: Standard Return Policy -$10.00  Instant $49.99
$39.99 1 13-138-368-05.jpgBIOSTAR NM70I-847 Intel Celeron 847 1.1GHz 2C/2T BGA1023 Intel NM70 Mini ITX Motherboard/CPU Combo
Item #: N82E16813138368
Return Policy: Standard Return Policy -$30.00  Instant $79.89
$49.89 1 20-242-008-01.jpgKingston 16GB DataTraveler Mini 3.0 USB 3.0 Flash Drive
Item #: N82E16820242008
Return Policy: Standard Return Policy   $8.99 1 20-313-471-01.jpgTeam Elite 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model TED34G1600C1101
Item #: N82E16820313471
Return Policy: Memory Standard Return Policy -$4.00  Instant $34.99
$30.99 1 33-704-060-04.jpgTP-LINK TG-3468 10/ 100/ 1000Mbps PCI-Express Network Adapter
Item #: 9SIA24G15U7172
Sold by antonline.com policyQuote.gif -$10.18  Instant $26.99
$16.8
Thoughts and opinions? Pfsense can be installed on that USB stick, right?
Well, a DMZ is not necessary if you don't have plans to publish/expose anything. But yeah, you can put more ports than you need now so you wouldn't have to worry later.
I do have a suggestion that you get an Intel NIC (dual- or quad-port gigabit). They typically come in PCIe x4 cards and should work with the board you posted (the specsheet says it has a physical PCIe x16 slot but only wired for x8 and below)
The onboard "desktop-class" NIC (Realtek) on the said motherboard, I don't typically trust for tasks that I'd consider critical such as a router or firewall. Our office pfSense uses D-Link gigabit NICs (Realtek chipsets), which was all we had at the time, and we're experiencing packet loss under certain conditions. But if you still want to use the onboard NIC, you only need one additional port. Make that an Intel NIC. A single-port Intel gigabit NIC comes in PCIe x1 card, and should also fit your board.
