Backup Service not Running and other errors
sdtex
For for approxiamately the  past week, (ever since the most recent Windows Update I believe) I'm noticing that my CPU is maxed out, the backup service is disabled, demigrater and backup constantly running are generating large log files, and the c drive is full.
Is anyone else noticing unusual behavior on the V1 boxes?  Any ideas as to what may be causing this (am I correct in attributing it to something with the updates) ?
Platform -
HP Mediasmart EX485
modded BIOS to EX495
quad core CPU
  • Replies 52
  • Drashna Jaelre
    6
  • jmwills
    12
    19
  • sdtex
    16
Are you saying the C: drive is full because of log files?
Not sure what's filling up the drive just yet.
When I look at the following location
C:\WINDOWS\system32\LogFiles
There are ~136meg of log files going back several years.
C:\Documents and Settings\All Users\Application Data\Microsoft\Windows Home Server\logs
There are several gig of files.
THe largest being named
DEUtil.calendardate.numbers.log
Basically they are filled with lines similar to this
1/17/2015 9:20:16 AM 15fc] DriveExtenderService constructor
[1/17/2015 9:20:16 AM 1754] Starting Drive Extender Filter.
[1/17/2015 9:20:16 AM 1754] DEFilter!MoveInterloperWorker: Error c0000102 opening \Device\HarddiskVolume3\DE\folders\{00008086-058D-4C89-AB57-A7F909A47AB4}\{E0CB565C-3ED6-4C1C-BB0E-20CBC75F03D9}.Machine.configdat
I have Home Server SMART Addin and haven't gotten indication of a bad disk.
In my mediasmart server (which has 4 bays), I believe the top bay would be disk three (with the first slot being disk 0 and also the sys disk).   I have that top slot occupied with a disk that I back up the server.
I have just removed this drive by first going to the server storage tab and clicking remove and then physically removing from the server.
If I have the drive numbering incorrect, I suppose that one of my drives that drive extender uses could be failing but wouldn't SMART detect this?
I believe you have the numbering correct. Also, I think I would want to know what's taking up all the space. A drive that's too full could interfere with backups.
Thats 10% of one gig so your issue is not there with regards to space.
Run this PowerShell script to see where the largest files/folders are:
http://robwillis.info/data/scripts/lowDiskSpace/lowDiskSpace.txt
If you get an error message saying scripts are disabled, run this one first:
Set-ExecutionPolicy RemoteSigned
Most likely the backups are failing because Windows wants some space to create a Shadow copy and you have none.
Kinda of a novice.
How do I run this script?
