How to rip massive CD collection to iTunes (unattended)?
juzzle
Hi all,
I have a few thousand CDs in my collection, most of which are not yet ripped to iTunes. For many years, I've promised myself I would get them all digitally ripped.  Question is - how?  I had it in mind that the Imation Stakka (rotary style carousel type change) was the key, but it seems it never was able to do such a thing (and is no longer supported anyway).
So now I thinking a rack of 10 CD readers in some time of external enclosure.  Can anyone give me some starter ideas?
Many thanks,
Justin
MyMovies allows for DVD and CD ripping, and I believe it supports multi disk readers.
This would be the simplest way to do so, but a bit on the pricy side, IIRC.
Hmmm, this seems like a pretty difficult task. Even with a multidisc reader tower, what software would allow for automatically ripping from each reader in the tower? I don't know if such a thing even exists. Even if it did, the biggest towers I recall seeing help about 12 readers. It would take a lot of work to rip thousands of discs.
Before I'd invest all the money in the equipment, I would do some research to see how much of that is already up on Amazon, for FREE
I have a few thousand songs, but a few thousand CD's? I envy you. :)
Worst case would be, rip a dozen CD's everytime you're in front of the computer... slowly but surely. You'll get to the hundreds then thousands before you know it. Sorry I can't be further help.
Thank you Drashna
That did occur to me, but I kinda want to keep it all in the iTunes universe - you know, I trust the quality, the levels adjustment and the error correction.
Thank you Ikon,
I am half tempted to buy a 10 slot tower ($200?) and 10 slimline CD/DVD readers (@$30) - but I'd much prefer to buy a ready to go one - at $400, it would be easy to flog off when I was done.
Fortunately iTunes is multi-CD-aware, whilst they all can't be ripped with one command, you can cycle through the CDs and kick the process off - near enough for me:
Thank you JMWills
Don't you have to stick in your CD in order to verify you own the physical media? Yeah, kinda defeats the purpose methinks ;)
Yeah OJ, I hear you ..
But it's like pulling teeth :blink:
Hi all,
Many thanks,
Justin
There's this.
http://www.binaryscene.com/2010/09/patrick-nortons-cd-ripping-monster.html
Thank you Drashna
Thank you Ikon,
Thank you JMWills
No.  If you are a Prime Member, they run sort of a de-duplication archive to keep from having the same media up there thousands of times.  But to answer the original question, heck, you've spent upwards of $15k on all this music (my guess), whats $500 or so to rip it all?  As we would say at work, "hire an intern".
awraynor, the Monster Ripper + dbPowerAmp sounds like an awesome combo.
juzzle, if you combine dbPowerAmp (paid version) with a purpose-built CD/DVD tower, it sounds like you might have your answer. There is one thing though: I've noticed that some of the towers with, say, 12 readers, require a SCSI connection to the host computer. You probably don't have that on your computer (not many people do anymore). SCSI cards can be pretty expensive.
I did find these little beasties from Addonics: http://www.addonics.com/category/dvd-cd-tower.php. They use eSATA connections, which makes it a lot easier. You do need eSATA connection(s) that have Port Multiplier. The 9 disk unit requires 2 eSATA connections; the 5 disk requires 1 eSATA, and the 3 disk can use 1 eSATA or USB.
