ikon 439 Posted January 15, 2015 Share Posted January 15, 2015 OK, that's good, so far. I'm not sure port 4125 is tested by the default ShieldsUP! probe. You may have to use the Use Specified Custom Port feature. You enter 4125 into the box just above the button, then click the Use Specified Custom Port button. Link to post Share on other sites
g725s 18 Posted January 15, 2015 Author Share Posted January 15, 2015 (edited) OK, that's good, so far. I'm not sure port 4125 is tested by the default ShieldsUP! probe. You may have to use the Use Specified Custom Port feature. You enter 4125 into the box just above the button, then click the Use Specified Custom Port button. Probe port 4125: Port |Status | Protocol and Application 4125 | Stealth | Unknown Protocol for this port Probe of port 443: Port | Status | Protocol and Application 443 | OPEN! | https Probe of port 80: Port | Status | Protocol and Application 80 | Stealth | http What would be the work around since my ISP (cox.net) blocks inbound on port 80? Edited January 15, 2015 by g725s Link to post Share on other sites
ikon 439 Posted January 15, 2015 Share Posted January 15, 2015 Is there a reason you really need to use port 80? If not, you can access your server from outside your LAN by using https:// instead of http://. Remember, it's very likely you cannot do this from a computer on your LAN. It has to be from the Internet. Link to post Share on other sites
jmwills 284 Posted January 15, 2015 Share Posted January 15, 2015 The Site uses 443 so try and see without forwarding 80 Link to post Share on other sites
g725s 18 Posted January 15, 2015 Author Share Posted January 15, 2015 (edited) The Site uses 443 so try and see without forwarding 80 What is the purpose of port 80 then? I can access the https:// signin page from my phone at this point. I have intermittent data coverage from my home and was not able to check this earlier. But I'm unable to signin from my phone. It is saying username or password incorrect. I have never tired accessing this page from my phone before. Edited January 15, 2015 by g725s Link to post Share on other sites
ikon 439 Posted January 15, 2015 Share Posted January 15, 2015 Port 80 is just the default, unprotected web page port. In reality, it's much better if you use HTTPS (port 443), because it's encrypted using SSL. If you can't sign in, it may be because you haven't set the username you're trying to use to allow remote access. Use the DashBoard to check the User's permissions. Right-click on the Username, select View The Account Properties, then click on the Remote Web Access tab in the window that pops up. If nothing is checked there, you can't access. Link to post Share on other sites
g725s 18 Posted January 15, 2015 Author Share Posted January 15, 2015 Port 80 is just the default, unprotected web page port. In reality, it's much better if you use HTTPS (port 443), because it's encrypted using SSL. If you can't sign in, it may be because you haven't set the username you're trying to use to allow remote access. Use the DashBoard to check the User's permissions. Right-click on the Username, select View The Account Properties, then click on the Remote Web Access tab in the window that pops up. If nothing is checked there, you can't access. It has been a while since I used this I forgot and was using my Windows Live account name and password to access the page. If I use the client computer name I get to the page. Thanks Link to post Share on other sites
ikon 439 Posted January 15, 2015 Share Posted January 15, 2015 Ah. That would do it It sounds like you're good to go then... Link to post Share on other sites
g725s 18 Posted January 15, 2015 Author Share Posted January 15, 2015 Ah. That would do it It sounds like you're good to go then... Is there a workaround to access it from inside my LAN? Link to post Share on other sites
jmwills 284 Posted January 15, 2015 Share Posted January 15, 2015 Nope. That's your router doing that. Just RDP into the server, or go into the Site from IIS. Link to post Share on other sites
