N40L 3TB Drive Problem
Louie
Hello all,
I been searching for the last couple hours for some kind of answer to my issue. I went 'on the line' hahah for upgrading my memory and adding more drives to my N40L server. At the moment I have 10 gig of memory and 250gig drive that came with it. I added other 300gig drive that I had laying around. That was working fine until i started to run out of space. So I decided to buy other drive with lots of space.
I read on the forum that this drive would be go to install and works perfect WD Red 3 TB NAS Hard Drive: 3.5 Inch, SATA III, 64 MB Cache - WD30EFRX   Everything went fine BIOS see's it but for some reason it's showing up as 270gig drive. Since I have server 2012 r2 hyper-v core installed I ran diskpart and notice it was a smaller drive.
What am i missing from here. Do I need to make a chance to BIOS settings? I added a image from the boot process. Maybe someone could point me in the right direction on fixing this issue.
IMG 4895
Thank you guys for the help. I had a big brain fart that I forgot to format the drive... ugh... Now i'm getting a little confuse. Currently I have the 230 gig drive that came with the box. I added a 300gb drive that I mention earlier. From looking at the screen shot below why is it showing that it's 2794gb?  Now that I installed the 3TB drive it's showing the same thing 2794gb... Can someone explain to me why it's doing this?
Disk 0 - default drive that came with the N40L 230gb drive
Disk 1 - added drive i had around that's 300gb drive
Disk 2 - New 3TB drive I installed tonight..
Volume 2 - is the 300gb drive
Volume 3 - 3TB drive
Could it be that Hypver-v server 2012r2 core can't read the full drive?
The only one thing that is working fine is my upgrade memory i just received. I'm at 16gig now ... I'm loving the speed it has now.
Thanks once again for helping me. Sorry for the image being so big.
Edited by Louie
Formatted capacity is reported in GiB, raw drive capacity is reported in GB.  So a 3000GB drive always formats to 3000GiB.
Basically, what you're seeing is correct.  Drive manufacturers quote size differently to everyone else.
See: http://blog.open-e.com/formatted-capacity-confusion-clarified/
Ikon correct ... it's just confusing why both drives are reading the same thing even tho one is 300gb and the other drive is 3TB. As long as I have the correct space it won't matter to me. But I want to make sure before I start storing vm's on the drive.
