Mr Bill Posted December 7, 2014 Share Posted December 7, 2014 Good day all, Now that OneDrive now has basically unlimited storage, I am looking at using it as my cloud backup solution and having it replace my CrashPlan online backup. Has anyone used a software product that will back up a computer to OneDrive? OneDrive has been opening up recently and letting other applications place hooks into a OneDrive account. Is there some drawback that I am overlooking? Thanks for your time. Bill Link to comment Share on other sites More sharing options...
awraynor Posted December 7, 2014 Share Posted December 7, 2014 Would this support revisions. You can search for previous versions within Windows, but are all of these backed up? I always remember that syncing is not backup and as much as I dislike the memory requirements of CrashPlan it is an unlimited true backup. I came home Thursday to find the entire contents of the Music folder empty and I hadn't opted to include it in my CrashPlan backup. I can redownload through my Zune subscription, but that takes a lot of time. I tried to mount a restore through 2011, but it just crashed my PC and failed. Boo 2011. Link to comment Share on other sites More sharing options...
Al_Borges Posted December 7, 2014 Share Posted December 7, 2014 I am also thinking of using Onedrive to replace Crashplan - OneDrive has an file size limitation - unless you have the backup program break up the backup set into smaller files , Onedrive wont work. Microsoft just increased the file size limit to 2G or so - I dont remember exactly - the change is being rolled out so not everyone has seen the increase However, I dont consider Crashplan to be my recovery source for bare metal restores - just offline continuous protection for data. OneDrive can also serve as local data backup - I have a synced onedrive folder on my home server as well as my laptop and main machine - so 3 local copies plus the "cloud" I use Acronis to make periodic backup images. storing on a separate offline USB drive Crashplan is wonderful program and very useful - however, it does take a lot of resources to run and a yearly crashplan account is about what a office365 subscription costs so if you will, you are getting office 365 for "free" Link to comment Share on other sites More sharing options...
Dave Posted December 7, 2014 Share Posted December 7, 2014 Would this support revisions. You can search for previous versions within Windows, but are all of these backed up? I always remember that syncing is not backup and as much as I dislike the memory requirements of CrashPlan it is an unlimited true backup. I came home Thursday to find the entire contents of the Music folder empty and I hadn't opted to include it in my CrashPlan backup. I can redownload through my Zune subscription, but that takes a lot of time. I tried to mount a restore through 2011, but it just crashed my PC and failed. Boo 2011. Did you happen to upload to any other service? Xbox360 or Amazon? I uploaded to Amazon and then re-downloaded the matched music which was cleaner and higher bitrates. Tsk Tsk Tony! Then again, my music folder is only 20 to 30Gb. I know you guys have massive collections. Link to comment Share on other sites More sharing options...
awraynor Posted December 7, 2014 Share Posted December 7, 2014 Did you happen to upload to any other service? Xbox360 or Amazon? I uploaded to Amazon and then re-downloaded the matched music which was cleaner and higher bitrates. Tsk Tsk Tony! Then again, my music folder is only 20 to 30Gb. I know you guys have massive collections. My owned music is in a separate folder which is also backed up on Amazon with a portion of that replicated on iTunes Match and Google Music. It is the subscription portion that I had to download. It is just time consuming to download it again while trying to remember everything that was already done. Still not sure why trying to mount a folder for restore made the PC crash. Will try to find some time to look at that. Edit: Mounted the folder backup from my notebook and restore worked fine. Link to comment Share on other sites More sharing options...
Drashna Jaelre Posted December 8, 2014 Share Posted December 8, 2014 I've see that actually... (BSOD caused by mounting a backup). Check the file system filters in the system, by running "fltmc" from an elevated command prompt. Also, I don't believe in the cloud. It's data that is in somebody else's data center. Period. End of story. Meaning that they can potentially sift through your data and look at it. In fact, the TOS or EULA probably explicitly allows that, as nobody actually reads those... except lawyers and masochists. I have a cloud server. I'm happy with it, and don't plan on changing things. Link to comment Share on other sites More sharing options...
ikon Posted December 8, 2014 Share Posted December 8, 2014 ^^ What he said. Not that I would never put anything in the cloud; only that I would never put anything personal or financial or that could harm me in any other way in the cloud. Link to comment Share on other sites More sharing options...
Zenon Posted December 9, 2014 Share Posted December 9, 2014 Hello, Do you encrypt data before sending them to the Onedrive or Amazon? I realize that not all data can be sensitive, but encryption is very important nowadays. Link to comment Share on other sites More sharing options...
ikon Posted December 9, 2014 Share Posted December 9, 2014 The stuff I put in the cloud I do not encrypt, but it doesn't need to be. If I was putting sensitive data in the cloud I would definitely encrypt, but I avoid all of the issues by not putting any sensitive in the cloud in any form.... it's a real good thing Link to comment Share on other sites More sharing options...
Jason Posted December 9, 2014 Share Posted December 9, 2014 What encryption techniques are people using to encrypt data going to either CP or OD? I know it's encrypted during transmission though not sure about storage on their host servers. Link to comment Share on other sites More sharing options...
