theguru1974 Posted November 23, 2014 Share Posted November 23, 2014 Hello everyone, I have searched the internet and read many threads relating to challenges in this area but couldn't find this exact scenario with a solution posted - a TS140 trying to do an unattended install of WHS2011 to get around the 160GB HD requirement. I have a Kingston SSDNow 120GB drive. Kingston Digital 120GB SSDNow V300 SATA 3 2.5 (7mm height) with Adapter Solid State Drive 2.5-Inch SV300S37A/120G) I have tried 2 methods, both putting the OS disc files and the cfg.ini on a usb key, and by having just the cfg.ini on the usb key along with using the OS disc in the optical drive. In both situations the unattended install doesn't trigger and I am presented with the first screen of the install wizard, and when clicking through get to the screen where it halts the install due to the target drive being < 160GB. I tried formatting the USB key as FAT32 due to a technical note I found on Lenovo's site but that didn't help. Thanks for your help. I've wasted half my weekend already trying this over and over and am getting quite frustrated! Eric Link to comment Share on other sites More sharing options...
schoondoggy Posted November 23, 2014 Share Posted November 23, 2014 Not sure about the unattended aspect, but JM has articles on installing on a small drive: http://homeservershow.com/forums/index.php?/topic/4259-installing-whs2011-on-a-small-ssd-in-a-microserver/ http://homeservershow.com/installing-windows-home-server-2011-on-a-ssd-in-a-hp-microserver-n40l.html Link to comment Share on other sites More sharing options...
HellDiverUK Posted November 26, 2014 Share Posted November 26, 2014 Which USB port are you using? Make sure you're using the USB2 port under the LAN connection. The USB3 sockets (all the rest) won't work during WHS2011 install. 1 Link to comment Share on other sites More sharing options...
jmwills Posted November 26, 2014 Share Posted November 26, 2014 Which USB port are you using? Make sure you're using the USB2 port under the LAN connection. The USB3 sockets (all the rest) won't work during WHS2011 install. Yep, those drivers don't get installed until the OS is installed. 1 Link to comment Share on other sites More sharing options...
ikon Posted November 26, 2014 Share Posted November 26, 2014 Yep, those drivers don't get installed until the OS is installed. Hopefully, that will change in the near future. Link to comment Share on other sites More sharing options...
HellDiverUK Posted November 26, 2014 Share Posted November 26, 2014 USB 3 works OK in Server 2012R2, but not on WHS2011 (as it's really just Server 2008R2 in a clown suit). 1 Link to comment Share on other sites More sharing options...
