ikon 439 Posted December 16, 2014 Share Posted December 16, 2014 He did, but I would prefer an explicit statement, just to be sure. Sometimes, small things get missed by not being explicit. Link to post Share on other sites
quickdry 0 Posted December 16, 2014 Share Posted December 16, 2014 sorry I wasn't more precise, that is correct - it is not showing up in Device Manager. Thanks for the info re: iLo only showing HP suported cards, this little server is an interesting beastie. Link to post Share on other sites
Shonk 139 Posted December 17, 2014 Author Share Posted December 17, 2014 No its pci-e 2.0 x2 The card you linked to is x1 as well..... Link to post Share on other sites
ikon 439 Posted December 17, 2014 Share Posted December 17, 2014 No its pci-e 2.0 x2 Thanks. I obviously missed that. Not that it matters in my case. I'm only using my card to do RoboCopies of my data to my NearLine and OffSite external boxes. The only things that get copied are new and changed files, which doesn't take long. Also, the RoboCopy scripts run 1 after the other, so the full throughput of the card is dedicated to each box while it's being updated. Nevertheless, it's good to know that a x2 card exists. Link to post Share on other sites
Shonk 139 Posted February 10, 2015 Author Share Posted February 10, 2015 I have been waiting for some Zintec but was bored today so banged a few out on galv It all fits fine though the drive holes could do with 1/2 a mm tweaking Link to post Share on other sites
schoondoggy 900 Posted February 10, 2015 Share Posted February 10, 2015 Looks good! Nice work. Link to post Share on other sites
Shonk 139 Posted February 11, 2015 Author Share Posted February 11, 2015 Fitted it just now 8 internal drives (4x2.5" 4x3.5") moved the 2.5" esata drive inside and powered it from the internal usb port 13 drives now dont think im gona squeeze much more in Intel PCH Ports Sata Port 0 240GB SSD 2.5" Sata Port 1 6TB WD 3.5" Sata Port 2 3TB Seagate 3.5" Sata Port 3 3TB Seagate 3.5" Sata Port 4 3TB Seagate 3.5" Marvell 9230 Ports Sata Internal 0 2TB Samsung 2.5" Sata Internal 1 500GB Hitachi 2.5" Sata Internal 2 320GB Seagate 2.5" (Esata Port) Sata External 3 3TB Hitachi 3.5" (Esata Port) USB Ports Seagate Backup+ Portable 250GB USB3 Samsung G2 Portable 320GB USB2 Corsair Voyager GT 64GB USB3 Samsung UHS-1 Micro SD 64GB 1 Link to post Share on other sites
FISHERMAN 2 Posted February 11, 2015 Share Posted February 11, 2015 WoW....keep it coming ... Link to post Share on other sites
ikon 439 Posted February 11, 2015 Share Posted February 11, 2015 Nice job shonk. Link to post Share on other sites
Shonk 139 Posted February 11, 2015 Author Share Posted February 11, 2015 I was thinking about the bracket earlier And came up with a few things 1) Bottom drive screws dont need to be countersunk as they make no contact with anything 2) The bracket will contact at point circled on the first two images which may vibrate So i decided to go back in today and add 3 layers of 3m vhb so they become the contact point and are ofc cushoned whilst i was there i dug out a propper sata to esata cable and wired the power internally freeing up the internal usb port so i decided to strip the drive out of the Samsung G2 Portable and fit it internally Link to post Share on other sites
