Fans?
Haggis
I am adding hard dirves into the ODD bay so want a little cooling on the front
I am going to put a mesh on the odd opening
are these fans any good fir behind it?
Hi,
my answer would be: it depends ...
I did recently a similar modding and I put a 4 cm fan close to the drives to pull hot air away from drives to middle area of the microserver for being transported out by the big fan.
With checking the temperature values from raid controller I identified it is not sufficient enough. Thats what I would do in your case also. Make a little analyses of temperature values and play with different fans, if you have some.
