Monitoring temperature for N54L
afton
What software do you use to monitor CPU temperature on N54L? (in Windows)
Probably not quite your setup but I'm running the HP version of ESXi on my N54L. I installed the HP SIM pack and in the vSphere Client (under Windows) I can see this:
Hi yud, which particular version are you running?  Do you get any errors in /var/log/syslog.log?
(I'm seeing errors in my log file).
That looks good, could you please explain how to install the HP SIM pack?
I'm running the same version as you - 5.1 U2 - and am getting the same error. I will reply to your message in the other thread.
As for the HP pack:
I used the guide here: http://www.cosonok.com/2012/02/installing-hp-offline-bundle-for-vmware.html
The latest version of the offline pack for ESXi 5.0/5.1 can be found here: http://vibsdepot.hp.com/hpq/sep.19.2014/esxi-5x-bundles/hp-esxi5.0uX-bundle-2.1.1-2.zip
The full list for all vesrions of ESXi: http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=4161631&docId=emr_na-c04458499&docLocale=en_US
From memory I think I had to play with the precedure to get it installed properly (sorry, can't remember...), but once installed it is working flawlessly.
Thanks yud.
Strange though: I had a look at that bundle zip file, and as far as I can see it just contains 5 of the VIBs I already have installed (that came with 5.1 U2):
hp-smx-provider-500.03.06.00.23-434156.vib
char-hpcru-5.0.6.6-1OEM.500.0.0.434156.x86_64.vib
char-hpilo-500.9.0.2.3-1OEM.500.0.0.434156.x86_64.vib
hp-esxi-fc-enablement-500.2.1.8-434156.vib
hp-ams-500.10.0.1-07.434156.vib
