MicroSD Slot - what to do with it?
Homer-S
Hello again,
I knew about the MicroSD slot but I have no idea what it is good for or how I could use it.
Thanks for your help and hints
Ah ok,
Would this also work with Hyper V?
And if I plug a MicroSD card in, which dirve do I have to select for boot and will it be appear as a "normal" drive in diskmanager etc?
You need to be careful here. Do not use a MicroSD card to hold a Windows OS, or any other OS that writes to the system drive frequently; it will burn out the SD card quickly.
I've used micro sd (or usb, pretty same thing, micro SD having less components, it may be less likely to turn badly)
- Esxi
- Use it to store a boot partition to boot from ODD drive in AHCI mode
- You could use it to store an OS, say linux, but you'd need to store some os parts from other locations, tweak logs, etc... expert stuff but doable.
After reading a lot and testing ESXi 5.5 in a virtualbox VM I am pretty sure I will not go for ESXi. It seems that they changed there licensing system. You can only customize and setup new VMs for 60 days without purchasing a license.
Next to test would be Hyper-V (stucked with connecting from Win7 to server; account issue seems to be the point) or Xenserver.
Would it be possible to run Xenserver on a SD card or is there the same issue as Hyper-V?
