Please help me . about booting from slot 5 odd bay
wendows
hallo everyone,
im new here, i just bought a new Gen8. i have 3 Disks
                   2 old WD greed Disk 1G Sata3G in slot 3 and 4 installed and
                   1 Samsung SSD 250 Evo 840
i want to install ESXI on the SSD, using ssd as a vm pool, and booting from it.
i setup like this:
                   SSD (ODD) array 0 as port1 of the array controller.
                   2WD array 1 as Port 2 of the array controller.
                   Array Controller setup Port1 as primary boot disk.
then i find if i have all 3 disk installed after that setup.  i cant boot up Gen8.
i cant use F10 or F5 to active HP smart storage or  Inteligent Provisioning. or even worse, F9 F11 not funktion!
i just stuck here,and cant do anything. what i can do just power switch...
please give me some advice.  thank u so much.  sry for my poor english.
Are you booting from the ESXi install image?
i installed ESXi from ilo remote console.  i downloaded ESXi 5.5 for HP from VM webseit
but after install ESXi i cant boot up when other 2 WD Disks in Slot.
only with SSD i can boot up to ESXi
thank you for ur replay.
If the SSD is the only drive in the server it will boot?
Can you enter the SSA by hitting F5 if the SSD is the only drive in the system?
If so, please post a screen shot of the SSA configuration page.
thx, im working.  i will post it asap when i go back home.
thank u schoondoggy :)
now even worse....
i have disconnected my ssd, just have 2 WD Disk in Slot1 and Slot2
i cant even go in bios,  F9 F11 F5 not funktion.
i just stuck here
pls help T.T
Edited by wendows
i have tried from the beginning to configure this gen8,only i install the wd disk in slot 1 and 2
then still like #1. same picture.......
so my friends. i have tested it again.  same result..
System ROM J06 System ROM Date 06/06/2014 Backup System ROM Date 11/09/2013 Integrated Remote Console .NET    Java License Type iLO 4 Advanced iLO Firmware Version 2.00 Jul 30 2014
A: ODD SSD in, WD green Disk in Slot1 and Slot2, Problem same like 1#
B:  connect only ODD SSD. no other Disks
bios Einstellung> (like in the youtube video, virtual disk install enabled too)
then i can boot from this ssd to ESXi5.5, all ok.
Edited by wendows
