Rukah Posted October 19, 2014 Share Posted October 19, 2014 I just want to confirm before I buy...I have a N54L running a P410 RAID Controller. I want to add the Intel EXPI9301CTBLK Network card so that I have 2xNIC's.... I plan to use them with ESXi so I can learn about virtual switches etc.Does anyone have both a RAID Controller (Pref P410), External NIC and onboard NIC working? If so, was there anything you had to watchout for? Link to comment Share on other sites More sharing options...
ikon Posted October 19, 2014 Share Posted October 19, 2014 I don't see any reason why it wouldn't work. People are running multiple NICs in N54Ls when using them as routers/UTMs. However, I can't speak to the ESXi compatibility. From what I've heard, ESXi can be pretty picky, especially v5.5. Link to comment Share on other sites More sharing options...
schoondoggy Posted October 19, 2014 Share Posted October 19, 2014 It is an x1 card so you should be fine just confirm that it comes wit the low profile bracket. Link to comment Share on other sites More sharing options...
Rukah Posted June 4, 2015 Author Share Posted June 4, 2015 Bit of a late reply on this, but I wanted to double check before I buy the Intel EXPI9301CTBLK. It seems I can add the card to ESXi (its on the compatability list) - Hopefully without reinstalling? Some people have been reporting hardware bottlenecks on the PCI Bus when running a Hardware RAID Card (P410) and an External NIC. Has anyone experienced this/What kind of reduce speeds should I be expecting. And just to confirm, I intend to do "NIC Teaming" on ESXi with both the external/Internal Card - Is there any reason why this wouldn't work. Thanks Link to comment Share on other sites More sharing options...
