Podcast 96, Change EX47x power state to ON
diehard
Hi,
On Podcast 96 I mentioned that I have the EX490 and I changed the power state to always ON. Dave suggested that I post the direction on how to do this. Instead of repeating someone else's work, I'll point you the a great wiki from the mediasmartserver.net site.
http://www.mediasmartserver.net/wiki/index.php/BIOS_Power_Management_Setting
This is helpful if you have a brownout or power failure and would like your server to automatically power back up when the power is restored. You might be away from home during the outage, this saves you a trip to turn on the server manually.
NOTE: I'll double check that the instructions are the same for the EX49x as they are for the EX470 since I built a VGA/PS2 cable.
