Hyper-v Multi NICS
Guest techyguyni
Guest techyguyni
Hi
I'm trying to add 2 Network Cards to the one VM, Is this possible, I have a dual NIC that I can dedicate to my VM But cant for the life of me get my head around this, I've gooled with no results as to what I need. Hoping for a guru to help me out with this.
I think what you need to do is go intot he virtual switch manager and create a virtual switch for each NIC.
Then you can go into the VM settings and add a 2nd network card associated with the 2nd virtual switch.  Make sure the VM's are shut down.  I don't think you can do it on live VMs.
Guest techyguyni
I did it, I must be blend, thanks for your response anyway.
I went into add hardware then added the second nic, all is well.
I am going to delve into vm monitoring next
