Potential server build using ThermalTake Core V1
schoondoggy
SFF server base $575
i3
16GB
IPMI
Thermaltake Core V1 Extreme Mini ITX Cube Chassis,
Compatible with air and Liquid Cooling Builds (CA-1B8-
00S1WN-00)
Model #:CA-1B8-00S1WN-00
Item #:N82E16811133260
$49.99
TYAN S5533GM2NR-LE Mini ITX Server Motherboard
LGA 1150 Intel C222 DDR3 1600/1333/1066
Model #:S5533GM2NR-LE
Item #:N82E16813151295
$179.99 -$20.00 Instant $159.99
Thermaltake TR2 TR-600 600W ATX12V v2.3 SLI
CrossFire Power Supply
Model #:TR-600
Item #:N82E16817153166
Return Policy:Standard Return Policy
Mail in Rebate Card
$64.99 -$15.00 Instant $49.99
Intel Core i3-4350 Haswell Dual-Core 3.6GHz LGA
1150 54W Desktop Processor Intel HD Graphics 4600
BX80646I34350
Model #:BX80646I34350
Item #:N82E16819116994
$149.99 -$5.00 Instant $144.99
Crucial 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3
1600 (PC3 12800) ECC Unbuffered Server Memory
Model CT2KIT102472BD160B
Model #:CT2KIT102472BD160B
Item #:N82E16820148770
$169.99
Subtotal: $574.95
As schoondoggy says. Mostly. :)
IPMI is done with a chip on the board, and handled separately from the CPU. It's nice, exact that the remote console is usually handled via java... and with a self signed cert.
Intel vPro aka, Intel AMT depends on the motherboard *and* CPU for support. It uses VNC. It requires RealVNC Viewer Plus to do the power "button" and virtual media stuff. But it costs $100 for the Viewer Plus license.
Another thing, IPMI uses a dedicated NIC that isn't visible to the OS, and is why these boards tend to have 3 NICs. Intel's AMT shares the NIC and tends to have only 2.
And sharing the NIC isn't necessarily a good thing. There is a known issue with the shared NIC being downgraded to lower speeds. Which requires rebooting to fix.
I've used both (IPMI on an ASRock RACK miniITX board, and intel vPro on a Supermicro board, model in signature). I can't say I like one over the other, really. I like that IPMI is free, but I hate using java.
