Wireless Router recommendation please
cskenney
schoondoggy
cskenney, so what did you end up buying and are you satisfied with it?
schoondoggy, is it easy to set up the firewall and AP's. I have never done it but am very interested in a separate device for wireless.
Setup on a WAP is very similar to the steps you would take setting up the wireless on a router. Amped Wireless and Ubiquiti make great products and their setup tools are very good. The EnGenius WAP I am running is very good, but the software is mediocre.
As far as consumer level wireless routers are concerned, you can turn them into pure Access Points by simply not using the WAN port. Connect a LAN port on the router to your Ethernet switch, set up your wireless parameters, leave the WAN port empty, and you automatically have a wireless AP.
You can do that, but I have not found them to give the same range and coverage as a WAP.
Really? I haven't had any issues with that. Mind you, I was mostly using WRT54G routers. Which ones gave you problems?
Yes indeed. Each AP should be on its own channel, preferably 2 or more channel numbers away from the channels being used by the APs, to avoid any overlap: e.g. with 3 APs use channels 1, 6 & 11; with 4, use channels 1, 4, 7 & 11. Of course, this is only possible if there are no competing routers in your area (e.g. like your neighbours).
I had been running multiple AP, but one really good one now covers our entire house, two story with a basement.
  • Replies 88
    23
  • Drashna Jaelre
    11
  • jmwills
    8
  • Poppapete
    7
Popular Posts
As a tip, I installed a program called Xirrus Wifi Inspector (was recommended in another thread) on a laptop and put it in a spot where I wanted great signal.  I then played around on the router with
Great feedback. I am using my RT-N66U as a glorified access point and my Sophos UTM as my firewall and VPN server. Will eventually want to upgrade from 802.11n to 802.11ac.
All good points oj88, and all among the reasons why I recommend testing. For me, there really is no substitute to practical, real-world testing.
Consumer level WAPs from most companies are just their Wireless Routers with the router part made inaccessible, and they charge more for them. :angry: I know this was true of most Netgear, Linksys, and Buffalo units, having dissected many of them. A Buffalo engineer even admitted it to me over the phone once.
That said, it's not true of Ubiquiti. They make good stuff, and it's really inexpensive considering the quality.
I have no idea about Amped, since I've never used any of their stuff.
EnGenius was very hit and miss for me. Some of the products were very good; others, not so much. However, YMMV because I found out that EnGenius Canada and EnGenius USA are different companies, and the products also vary.
Drashna Jaelre
Haven't used Sophos. Didn't know they make an AP.
They're really expensive, support multiple SSIDs per device, and VLAN support.
Also, you set them up entirely from the Sophos UTM device. :)
http://www.sophos.com/en-us/products/secure-wifi.aspx
https://www.sophos.com/en-us/products/secure-wifi/tech-specs.aspx
OOOOOO!!! They released a wireless AC version recently!!! ....
Speaking of "enterprise tech at home"... :P
Yeah, I saw that. Interesting. Didn't notice if that's also possible using a home brew Sophos UTM.... probably not.
Drashna Jaelre
The home license has option for it turned on, so it's available for home use.
And the only different between a home brew and the appliances sold is one is a hardware solution and the other is a software solution.
However, that's part of why I want to get one, it's the only section I HAVEN'T played with on Sophos UTM yet.
And apparently, it DOES have a guest WiFi option too (like commercial APs at starbucks and the like).
Drashna Jaelre
No, it is a great idea, they work very well with the UTM.
Exactly. I should see about getting one for review. ;)
Yeah, Sophos make it pretty clear on their website that their units have Guest access.
    • JROrtiz
      By JROrtiz
    • Jason
      By Jason
      Have been running a Windows DHCP server on home WSE12R2 box for quite some time behind my Sophos UTM firewall. Also allowed me to seamlessly run Windows Deployment Services at home. WDS just worked.
      But if I needed to make a particular LAN IP address exception on the firewall, I had to 1.) create a Windows DHCP server reservations AND 2.) create a network definition for that IP on the Sophos UTM box. 2 steps. Not very efficient; was sure I was doing something incorrectly...
      Tried to migrate to Sophos UTM running the DHCP Server, but now WDS doesn't work. LAN devices can no longer PXE boot. Seems possible. Many guides. None have proven especially successful.
      Is it possible to run a Windows DHCP server and have Sophos UTM import DHCP reservations instead of maintaining 2 unique entries for each IP reservation (one in Windows DHCP, another on Sophos UTM box)?
      What is best practice?
    • donschmidt
      By donschmidt
      Good morning.  I've just  purchased a home still under construction and plan to have CAT6 installed throughout the living areas. I'm hoping that someone can advise me as to the specific quality/specs of cable that I should use.
      Thanks and Happy New Year.
    • Joe_Miner
      By Joe_Miner
      I've been looking at the Intel Compute Stick BOXSTK1AW32SC and was wondering if anyone here has experience with that and if the Intel AC 7265 built into it is backwardly compatible with older N and A,B wifi?
    • heavy21
      By heavy21
      I want to optimize the performance and security of my home network of servers, PCs, laptops printers, smartphones, TVs, etc.  Current network appliances include layer 2 and 3 switches (Cisco small business) and Linksys router.  I’m looking to replace the Linksys with a security (pfSense) router appliance (w/OpenVPN).  I will also be adding security cameras and a NVR to the network.
      The gigabit network is straightforward in structure with all Ethernet connections hanging off the24 port switch connected to the cable modem and router except a cascaded 8 port switch in a room to provide 4 Ethernet connections in a room with only one data port.  Wireless connections presently come off the Linksys but will eventually come off the to-be-purchased security/router appliance with a wireless card.  I don’t see more than 100 devices in total for the whole network.  No VLANS and no sub-netting.  All hardware supports IPv6.
      Hardware line up is:
      Dual Zeon server w/RAID 10 of 24 TB of storage, 64GB memory
      Cisco managed switches layer 2 and 3
      HPEX495 server
      Workstations, Desktops, Laptops, Tablets, iPads
      Printers
      Software line up is:
      Windows Server Essentials 2012 R2, single domain controller, storage and file server duties
      Windows 10 Pro all non-server Intel computing devices
      PLEX server for streaming audio and video to display units
      Office 365
      From what I’ve read so far, it appears that I need to incorporate an IP addressing scheme for clients and servers on the network.  It would also appear that I need to implement VLANS and/or sub-netting to protect access to certain files and security footage, provide guest networking with future consideration for electronic door locks and some sort of server based media distribution to various display devices,
      What are best practices on assigning client and server devices to IP ranges, fixed or dynamic IP addresses?  Do I need to assign clients or servers to IP ranges?  What are the considerations in establishing sub-nets over VLANS or vice versa?  I’m pretty sure I want to restrict access to cameras and their security footage and personal files on my workstation.
      Thanks for any resources and advice provided.
