cskenney
Wireless Router recommendation please
itGeeks
I wouldn't call that a cheap price of admission for home users. It's not outrageous, but it's not cheap either. The other issue I have is that inSSIDer's ability to detect noise is going to be dependent on the particular transceiver unit in the computer being used to scan. Transceivers can vary quite a bit. Also, different transceivers will react to noise differently. InSSIDer's suggested channel could be a good starting place, or a reasonable selection if time is a constraint but, in the end, I still believe that real-world testing is the only way to find the very best channel.
O ikon, I dont know you but I think I love you :) No punt intended. I guess this is a shootout of Democratic Party vs Republican Party :P LOL. All kidding aside, I agree with some of what your saying. You are correct in that it will be dependent on the particular transceiver unit in the computer or device being used to scan the network however the inSSIDer package that I talked about "inSSIDer Office & Wi‑Spy Mini that cost 199.99" includes a USB Dongle so it would not be dependent on the internal WiFi card of the device being used & I stand strong in saying 199.99 for this type of tool is cheap for all the power you get to fix your own WiFi trouble or if your the friends & family IT guy that everyone calls when something is not working right, I don't know about you but my time is worth 95.00 an hour so if I can go in and fix something quick because I used the right tool then that's a good day for me. I am not saying that everyone should go out and purchase this kit however if your having WiFi trouble and you need a good tool to try and figure out whats going on with your WiFi Network this price is well worth it unless of course you want to just play with setting for days, weeks, months in hopes of getting it right or maybe even better just pay someone 400-500 dollars to come in and do a wireless survey to see whats going on....Just my 2 cents.
ikon
Ah, the pro version comes with its own NIC. That does change things, in that it helps inSSIDer give much more consistent results than it would if it depended on the built in NIC. It helps explain some of the cost too :)
Last time I used inSSIDer I don't think there was such a version available. The version I used was free, but apparently there is no free version anymore: the minimum is now $20US. There is a 30-day, money back guarantee.
itGeeks
Last time I used inSSIDer I don't think there was such a version available. The version I used was free, but apparently there is no free version anymore: the minimum is now $20US. There is no free version any more, but there is a 30-day guarantee.
That is correct, there is no more free version. I also had the free version for a long time but recently shelled out the cash for the paid version because Meta Geeks has a great product. Glad you seem to agree now & sorry for the jokes but I could not help myself :)
I personally want to thank you for your hard work in helping all of us in this community, I know you post allot and you have tried to help me with trouble I was having in the past so hats off to you ikon, Keep up the hard work. Its people like you that make this community so great!!
Happy Holidays!!! to you and your family
ikon
That's awfully kind of you to say. I do it because I agree it's a great community: no flamers, snobs, or others who bring negativity.
Happy holidays to you and yours... :)
ImTheTypeOfGuy
cskenney, so what did you end up buying and are you satisfied with it?
schoondoggy, is it easy to set up the firewall and AP's. I have never done it but am very interested in a separate device for wireless.
Drashna Jaelre
Depends on the device. and the firmware. But generally pretty easy.
The open source firmware routers make it really easy to set up an independent AP.
I use dd-wrt and my Linksys E3000 is working as JUST an AP now.
Another option is the powerline "repeaters" which can work as an AP as well.
ikon
As far as consumer level wireless routers are concerned, you can turn them into pure Access Points by simply not using the WAN port. Connect a LAN port on the router to your Ethernet switch, set up your wireless parameters, leave the WAN port empty, and you automatically have a wireless AP.
Drashna Jaelre
True, but I've played with a few linksys' that REALLY didn't like it if you did that...
jmwills
And use different channels than your other wireless devices.
ikon
Really? I haven't had any issues with that. Mind you, I was mostly using WRT54G routers. Which ones gave you problems?
Yes indeed. Each AP should be on its own channel, preferably 2 or more channel numbers away from the channels being used by the APs, to avoid any overlap: e.g. with 3 APs use channels 1, 6 & 11; with 4, use channels 1, 4, 7 & 11. Of course, this is only possible if there are no competing routers in your area (e.g. like your neighbours).
    • JROrtiz
      By JROrtiz
    • Jason
      By Jason
      Have been running a Windows DHCP server on home WSE12R2 box for quite some time behind my Sophos UTM firewall. Also allowed me to seamlessly run Windows Deployment Services at home. WDS just worked.
      But if I needed to make a particular LAN IP address exception on the firewall, I had to 1.) create a Windows DHCP server reservations AND 2.) create a network definition for that IP on the Sophos UTM box. 2 steps. Not very efficient; was sure I was doing something incorrectly...
      Tried to migrate to Sophos UTM running the DHCP Server, but now WDS doesn't work. LAN devices can no longer PXE boot. Seems possible. Many guides. None have proven especially successful.
      Is it possible to run a Windows DHCP server and have Sophos UTM import DHCP reservations instead of maintaining 2 unique entries for each IP reservation (one in Windows DHCP, another on Sophos UTM box)?
      What is best practice?
    • donschmidt
      By donschmidt
      Good morning.  I've just  purchased a home still under construction and plan to have CAT6 installed throughout the living areas. I'm hoping that someone can advise me as to the specific quality/specs of cable that I should use.
      Thanks and Happy New Year.
    • Joe_Miner
      By Joe_Miner
      I've been looking at the Intel Compute Stick BOXSTK1AW32SC and was wondering if anyone here has experience with that and if the Intel AC 7265 built into it is backwardly compatible with older N and A,B wifi?
    • heavy21
      By heavy21
      I want to optimize the performance and security of my home network of servers, PCs, laptops printers, smartphones, TVs, etc.  Current network appliances include layer 2 and 3 switches (Cisco small business) and Linksys router.  I’m looking to replace the Linksys with a security (pfSense) router appliance (w/OpenVPN).  I will also be adding security cameras and a NVR to the network.
      The gigabit network is straightforward in structure with all Ethernet connections hanging off the24 port switch connected to the cable modem and router except a cascaded 8 port switch in a room to provide 4 Ethernet connections in a room with only one data port.  Wireless connections presently come off the Linksys but will eventually come off the to-be-purchased security/router appliance with a wireless card.  I don’t see more than 100 devices in total for the whole network.  No VLANS and no sub-netting.  All hardware supports IPv6.
      Hardware line up is:
      Dual Zeon server w/RAID 10 of 24 TB of storage, 64GB memory
      Cisco managed switches layer 2 and 3
      HPEX495 server
      Workstations, Desktops, Laptops, Tablets, iPads
      Printers
      Software line up is:
      Windows Server Essentials 2012 R2, single domain controller, storage and file server duties
      Windows 10 Pro all non-server Intel computing devices
      PLEX server for streaming audio and video to display units
      Office 365
      From what I’ve read so far, it appears that I need to incorporate an IP addressing scheme for clients and servers on the network.  It would also appear that I need to implement VLANS and/or sub-netting to protect access to certain files and security footage, provide guest networking with future consideration for electronic door locks and some sort of server based media distribution to various display devices,
      What are best practices on assigning client and server devices to IP ranges, fixed or dynamic IP addresses?  Do I need to assign clients or servers to IP ranges?  What are the considerations in establishing sub-nets over VLANS or vice versa?  I’m pretty sure I want to restrict access to cameras and their security footage and personal files on my workstation.
      Thanks for any resources and advice provided.
