Wireless Router recommendation please
cskenney
I'm currently using ASUS' RT-AC87R (the U is the same thing, the R is just the "retail" version sold at big box stores), their top-end unit.
I'd probably recommend the RT-AC68U, their second from top-end.  You save money, and the one feature you lose is a long way off from use (Quantenna 5GHz radio for MU-MIMO, which requires compatible MU-MIMO clients, which aren't available yet).
The key to the AC68 and AC87 are that you get dual-core processors.  Lower-end ASUS units don't have this, which is fine, until you want to run either an OpenVPN server or client.  The encryption used by OpenVPN tunnels bogs down the single-core variants, as it takes a lot of horsepower.  Not an issue with the 68 or 87.
If you're not into ASUS, the NetGear Nighthawk R7000 has similar specs/features, but the availability of custom firmware isn't quite as nice as on the ASUS.  Should also be a good unit.
As much as I like my RT-AC87, I'm wishing a little that I went one model down to the AC-68, as I now have a WatchGuard XTM-25 firewall, which may become my router, and the AC-87 just an access point on steroids.
I had one of these for two months but ended up returning it because it was dropping the WiFi 5.0 GHz channel & when I say dropping I do mean the channel went totally dead for a few seconds then would come back online, I had the unit for two months in hope of a firmware update that would fix this as well as enable some of the features that are not enabled yet. After waiting for two months with no sign of a new firmware I decided to return it for a full refund - Love Amazon :D
I have now purchased a Open-Mesh MR-900 access point and I must say I could not be happier http://www.open-mesh.com/products/access-points/mr900-dual-band-cloud-access-point.html
  • Replies 88
    23
  • Drashna Jaelre
    11
  • jmwills
    8
  • itGeeks
    7
Popular Posts
As a tip, I installed a program called Xirrus Wifi Inspector (was recommended in another thread) on a laptop and put it in a spot where I wanted great signal.  I then played around on the router with
Great feedback. I am using my RT-N66U as a glorified access point and my Sophos UTM as my firewall and VPN server. Will eventually want to upgrade from 802.11n to 802.11ac.
All good points oj88, and all among the reasons why I recommend testing. For me, there really is no substitute to practical, real-world testing.
Jason - The RT-N66U is a great unit, I have several of these installed at friends & Family houses. How is your Sophos UTM working for you? Are you using this for home or business use??
I did try Sophos UTM as a possible replacement for my Untangle box but after one week of trying to get everything working again I decided to switch back to Untangle. I did like what Sophos had to offer for the most part but simple things like my family trying to play Netflix just was not working on Android Devices and my Crash Plan backups stopped working and I got very tired of it all, I went as far as allowing all outbound traffic but I still had trouble.
Fire up the ZyXel, I run a ZyWall 20.
For WAP I have had great luck with a EAP600 from EnGenius. Ubiquiti has great WAP's as well.
I have a two story house with a basement, the EAP600 is mounted on the second floor in the middle and covers the entire house.
ZyXel makes some great stuff as well. I use the ZyXEL Homeplug AV2 Gigabit Powerline Adapter to feed my four outdoor survalance camera's and they have been rock solid
http://www.amazon.com/dp/B00MUVFOH6/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=1N6867G1O15RY&coliid=IHYIHVRZKAT9J
I use a program called inSSIDer by MetaGeek. The program works great and unlike "Xirrus Wifi Inspector" you don't have to guess what channel to use because inSSIDer will tell you the recommend channel to use and though its not free software it is worth every bit of the 10.00 I pay for it on Android Market for my smart-phone, They also have versions that run on Windows, Mac. so give it a try if your having WiFi trouble, You will be glad you did. :)  http://www.inssider.com/
While this is certainly a convenient feature, I believe it's best to experiment with different channels to find the one that works optimally. I have noticed that the one that looks most free from scanning the channels is not always the best choice. Sometimes it's just weird. I'm sure the one recommended by inSSIDer (which I have used) will work, but it may not be the absolute best choice, and with wireless that matters.
Just to reinforce what was already said, apps such as inSSIDer only checks for RF emissions that complies with the WiFi standard. For example, it won't be able to detect nearby microwave transmissions, interference, or any other 2.4 or 5 GHz RF emissions (RC toys, cordless phones, etc.) that does not adhere to the IEEE 802.11 standard.
Not to mention that it is also limited by the radio capabilities of the test client where inSSIDer is running. If for instance, it doesn't support 802.11a, it won't be able to detect any 5 GHz APs. Or if it doesn't support 802.11n, the AP-test client link will fallback to 'g' or even 'b' standards and you won't be able to see 'n'-standard bonded channels, and such.
An RF signal analyzer is the ultimate tool for the job. It sees anything RF that is within it's bandwidth, WiFi or otherwise. But these are expensive and not many people would have one lying around in the workshop.
This has been some great conversation. For the most part I agree with you except inSSIDer can check for that part where you say "it won't be able to detect nearby microwave transmissions, interference, or any other 2.4 or 5 GHz RF emissions (RC toys, cordless phones, etc.) that does not adhere to the IEEE 802.11 standard." inSSIDer 4 basic wont but "MetaGeek" offer a package called inSSIDer Office & Wi‑Spy Mini that cost 199.99 that can scan for other interference and I think that's a cheap price of admission compared to other offerings.
https://www.youtube.com/watch?v=6PTgPK9nvek
Edited by MrFixit
I wouldn't call that a cheap price of admission for home users. It's not outrageous, but it's not cheap either. The other issue I have is that inSSIDer's ability to detect noise is going to be dependent on the particular transceiver unit in the computer being used to scan. Transceivers can vary quite a bit. Also, different transceivers will react to noise differently. InSSIDer's suggested channel could be a good starting place, or a reasonable selection if time is a constraint but, in the end, I still believe that real-world testing is the only way to find the very best channel.
    • JROrtiz
      By JROrtiz
    • Jason
      By Jason
      Have been running a Windows DHCP server on home WSE12R2 box for quite some time behind my Sophos UTM firewall. Also allowed me to seamlessly run Windows Deployment Services at home. WDS just worked.
      But if I needed to make a particular LAN IP address exception on the firewall, I had to 1.) create a Windows DHCP server reservations AND 2.) create a network definition for that IP on the Sophos UTM box. 2 steps. Not very efficient; was sure I was doing something incorrectly...
      Tried to migrate to Sophos UTM running the DHCP Server, but now WDS doesn't work. LAN devices can no longer PXE boot. Seems possible. Many guides. None have proven especially successful.
      Is it possible to run a Windows DHCP server and have Sophos UTM import DHCP reservations instead of maintaining 2 unique entries for each IP reservation (one in Windows DHCP, another on Sophos UTM box)?
      What is best practice?
    • donschmidt
      By donschmidt
      Good morning.  I've just  purchased a home still under construction and plan to have CAT6 installed throughout the living areas. I'm hoping that someone can advise me as to the specific quality/specs of cable that I should use.
      Thanks and Happy New Year.
    • Joe_Miner
      By Joe_Miner
      I've been looking at the Intel Compute Stick BOXSTK1AW32SC and was wondering if anyone here has experience with that and if the Intel AC 7265 built into it is backwardly compatible with older N and A,B wifi?
    • heavy21
      By heavy21
      I want to optimize the performance and security of my home network of servers, PCs, laptops printers, smartphones, TVs, etc.  Current network appliances include layer 2 and 3 switches (Cisco small business) and Linksys router.  I’m looking to replace the Linksys with a security (pfSense) router appliance (w/OpenVPN).  I will also be adding security cameras and a NVR to the network.
      The gigabit network is straightforward in structure with all Ethernet connections hanging off the24 port switch connected to the cable modem and router except a cascaded 8 port switch in a room to provide 4 Ethernet connections in a room with only one data port.  Wireless connections presently come off the Linksys but will eventually come off the to-be-purchased security/router appliance with a wireless card.  I don’t see more than 100 devices in total for the whole network.  No VLANS and no sub-netting.  All hardware supports IPv6.
      Hardware line up is:
      Dual Zeon server w/RAID 10 of 24 TB of storage, 64GB memory
      Cisco managed switches layer 2 and 3
      HPEX495 server
      Workstations, Desktops, Laptops, Tablets, iPads
      Printers
      Software line up is:
      Windows Server Essentials 2012 R2, single domain controller, storage and file server duties
      Windows 10 Pro all non-server Intel computing devices
      PLEX server for streaming audio and video to display units
      Office 365
      From what I’ve read so far, it appears that I need to incorporate an IP addressing scheme for clients and servers on the network.  It would also appear that I need to implement VLANS and/or sub-netting to protect access to certain files and security footage, provide guest networking with future consideration for electronic door locks and some sort of server based media distribution to various display devices,
      What are best practices on assigning client and server devices to IP ranges, fixed or dynamic IP addresses?  Do I need to assign clients or servers to IP ranges?  What are the considerations in establishing sub-nets over VLANS or vice versa?  I’m pretty sure I want to restrict access to cameras and their security footage and personal files on my workstation.
      Thanks for any resources and advice provided.
