Wireless Router recommendation please
cskenney
I've had a Linksys E2000 for some time and have had to reboot once in a blue moon.  There have been reports in the household of the wireless dropping, but only in the kitchen.  A direct line to the kitchen takes the signal through two outer walls.
Thanks for the ideas guys, I may just get one of these that support the Chromecast.
  • Replies 88
    23
  • Drashna Jaelre
    11
  • jmwills
    8
  • itGeeks
    7
Popular Posts
As a tip, I installed a program called Xirrus Wifi Inspector (was recommended in another thread) on a laptop and put it in a spot where I wanted great signal.  I then played around on the router with
Great feedback. I am using my RT-N66U as a glorified access point and my Sophos UTM as my firewall and VPN server. Will eventually want to upgrade from 802.11n to 802.11ac.
All good points oj88, and all among the reasons why I recommend testing. For me, there really is no substitute to practical, real-world testing.
GavinCampbell
As a tip, I installed a program called Xirrus Wifi Inspector (was recommended in another thread) on a laptop and put it in a spot where I wanted great signal.  I then played around on the router with the various channels and settings and looked at the signal differences.
When I first set it up my signal was at 66% and after going through all the available channels i found the best channel that gave my a signal of 98%.
This was the difference that allowed me to eventually stream 720p videos over the wireless N without problems.
I advise you give this a try if you are having signal issues in the house.  Maybe it will help.
It's always a good idea to use a WiFi sniffer when setting up APs. One of the main benefits is to identify which channels are the least used in your area, to reduce frequency contention.
Xirrus Wifi Inspector is the bomb!
Alternatively, if you detest doing wireless surveys lugging around a laptop, you can use an Android tablet or smartphone with either of the following apps: WiFi Analyzer or inSSIDer.
EDIT: Apparently, inSSIDer is no longer free. I still have the free version installed on my phone from way back.
One thing I noticed with wireless surveys is that the quality and sensitivity of the wireless gear in the unit being used to conduct the survey can heavily affect the results obtained. In some cases I've seen one laptop detect twice as many Access Points as another.
Look at the Ubiquiti Air Router. I have installed many of these and they are rock solid.
I'm running one of the Unifi access points along with a sophos router.
http://www.amazon.com/Ubiquiti-AirRouter-Indoor-WiFi-router/dp/B007ZJ8KLA/ref=sr_1_2?ie=UTF8&qid=1411695242&sr=8-2&keywords=air+router
The OS has built-in tools for analyzing nearby frequencies.
Edited by tojoski
LoneWolf
I'm currently using ASUS' RT-AC87R (the U is the same thing, the R is just the "retail" version sold at big box stores), their top-end unit.
I'd probably recommend the RT-AC68U, their second from top-end.  You save money, and the one feature you lose is a long way off from use (Quantenna 5GHz radio for MU-MIMO, which requires compatible MU-MIMO clients, which aren't available yet).
The key to the AC68 and AC87 are that you get dual-core processors.  Lower-end ASUS units don't have this, which is fine, until you want to run either an OpenVPN server or client.  The encryption used by OpenVPN tunnels bogs down the single-core variants, as it takes a lot of horsepower.  Not an issue with the 68 or 87.
If you're not into ASUS, the NetGear Nighthawk R7000 has similar specs/features, but the availability of custom firmware isn't quite as nice as on the ASUS.  Should also be a good unit.
As much as I like my RT-AC87, I'm wishing a little that I went one model down to the AC-68, as I now have a WatchGuard XTM-25 firewall, which may become my router, and the AC-87 just an access point on steroids.
Edited by LoneWolf
  • 2 months later...
I use a program called inSSIDer by MetaGeek. The program works great and unlike "Xirrus Wifi Inspector" you don't have to guess what channel to use because inSSIDer will tell you the recommend channel to use and though its not free software it is worth every bit of the 10.00 I pay for it on Android Market for my smart-phone, They also have versions that run on Windows, Mac. so give it a try if your having WiFi trouble, You will be glad you did. :)  http://www.inssider.com/
Disclamer: I have never used "Xirrus WiFi Inspector so I am assuming based on GavinCampbell post that becouse he had to manually go through all available channels till he found the best channel is the reason I say "unlike "Xirrus Wifi Inspector" you don't have to guess what channel to use because inSSIDer will tell you the recommend channel to use"
Edited by MrFixit
    • JROrtiz
      By JROrtiz
    • Jason
      By Jason
      Have been running a Windows DHCP server on home WSE12R2 box for quite some time behind my Sophos UTM firewall. Also allowed me to seamlessly run Windows Deployment Services at home. WDS just worked.
      But if I needed to make a particular LAN IP address exception on the firewall, I had to 1.) create a Windows DHCP server reservations AND 2.) create a network definition for that IP on the Sophos UTM box. 2 steps. Not very efficient; was sure I was doing something incorrectly...
      Tried to migrate to Sophos UTM running the DHCP Server, but now WDS doesn't work. LAN devices can no longer PXE boot. Seems possible. Many guides. None have proven especially successful.
      Is it possible to run a Windows DHCP server and have Sophos UTM import DHCP reservations instead of maintaining 2 unique entries for each IP reservation (one in Windows DHCP, another on Sophos UTM box)?
      What is best practice?
    • donschmidt
      By donschmidt
      Good morning.  I've just  purchased a home still under construction and plan to have CAT6 installed throughout the living areas. I'm hoping that someone can advise me as to the specific quality/specs of cable that I should use.
      Thanks and Happy New Year.
    • Joe_Miner
      By Joe_Miner
      I've been looking at the Intel Compute Stick BOXSTK1AW32SC and was wondering if anyone here has experience with that and if the Intel AC 7265 built into it is backwardly compatible with older N and A,B wifi?
    • heavy21
      By heavy21
      I want to optimize the performance and security of my home network of servers, PCs, laptops printers, smartphones, TVs, etc.  Current network appliances include layer 2 and 3 switches (Cisco small business) and Linksys router.  I’m looking to replace the Linksys with a security (pfSense) router appliance (w/OpenVPN).  I will also be adding security cameras and a NVR to the network.
      The gigabit network is straightforward in structure with all Ethernet connections hanging off the24 port switch connected to the cable modem and router except a cascaded 8 port switch in a room to provide 4 Ethernet connections in a room with only one data port.  Wireless connections presently come off the Linksys but will eventually come off the to-be-purchased security/router appliance with a wireless card.  I don’t see more than 100 devices in total for the whole network.  No VLANS and no sub-netting.  All hardware supports IPv6.
      Hardware line up is:
      Dual Zeon server w/RAID 10 of 24 TB of storage, 64GB memory
      Cisco managed switches layer 2 and 3
      HPEX495 server
      Workstations, Desktops, Laptops, Tablets, iPads
      Printers
      Software line up is:
      Windows Server Essentials 2012 R2, single domain controller, storage and file server duties
      Windows 10 Pro all non-server Intel computing devices
      PLEX server for streaming audio and video to display units
      Office 365
      From what I’ve read so far, it appears that I need to incorporate an IP addressing scheme for clients and servers on the network.  It would also appear that I need to implement VLANS and/or sub-netting to protect access to certain files and security footage, provide guest networking with future consideration for electronic door locks and some sort of server based media distribution to various display devices,
      What are best practices on assigning client and server devices to IP ranges, fixed or dynamic IP addresses?  Do I need to assign clients or servers to IP ranges?  What are the considerations in establishing sub-nets over VLANS or vice versa?  I’m pretty sure I want to restrict access to cameras and their security footage and personal files on my workstation.
      Thanks for any resources and advice provided.
