cskenney Posted September 23, 2014 Share Posted September 23, 2014 Please give me some ideas of an off the shelf router to consider. I have been using a DIR-655 for quite some time and it is starting to fail. WAF is low right now because she looses her connection. I don't want to build my own router at this time. Something I can plug in and use that has Wireless N, etc... you know...something that is somewhat modern. I have the option of using a Zyxell router and adding a wireless AP but so far I haven't messed with the Zyxell and I would still need a recommendation on the wireless. Link to comment Share on other sites More sharing options...
jmwills Posted September 23, 2014 Share Posted September 23, 2014 I am quite pleased with the Asus RT 66NU Link to comment Share on other sites More sharing options...
oj88 Posted September 23, 2014 Share Posted September 23, 2014 Asus is like the king right now on wireless routers, along with Linksys. A lot of models from both manufacturers can be flashed with 3rd-party firmwares from DD-WRT, Tomato or OpenWRT... if you're into that thing. That said, you can't go wrong with either. But personally, I'd go for Asus. Link to comment Share on other sites More sharing options...
schoondoggy Posted September 23, 2014 Share Posted September 23, 2014 Fire up the ZyXel, I run a ZyWall 20. For WAP I have had great luck with a EAP600 from EnGenius. Ubiquiti has great WAP's as well. I have a two story house with a basement, the EAP600 is mounted on the second floor in the middle and covers the entire house. Link to comment Share on other sites More sharing options...
ikon Posted September 23, 2014 Share Posted September 23, 2014 I've heard good things about the Asus as well. Link to comment Share on other sites More sharing options...
Jason Posted September 23, 2014 Share Posted September 23, 2014 I have an ASUS RT-N66U on a single floor and the range is moderate. Wouldn't count on it for a 2nd floor. Am in process of building a new house and will be loading up w 802.11n APs. Until AC takes hold. Link to comment Share on other sites More sharing options...
awraynor Posted September 23, 2014 Share Posted September 23, 2014 I'm using an Asus RT-AC68R and have had no problems. I used the Merlin firmware which adds to the stock firmware instead of completely replacing it. I bought it as a refurb for around $140 from NewEgg. I bought the Apple Airport Extreme Router from Dave at the meetup. I'll see how that does in comparison. Link to comment Share on other sites More sharing options...
jmwills Posted September 24, 2014 Share Posted September 24, 2014 Use your old routers as AP's on the new network. Link to comment Share on other sites More sharing options...
ikon Posted September 24, 2014 Share Posted September 24, 2014 Use your old routers as AP's on the new network. Yep, it's a good use for older wireless routers. Link to comment Share on other sites More sharing options...
awraynor Posted September 24, 2014 Share Posted September 24, 2014 Range isn't a problem at this time. Would there be any performance benefit to use one router for wireless duties and the other for wired data on my server and two desktops? As mentioned above my current router is the Asus AC router. Link to comment Share on other sites More sharing options...
