dvn
Home network config > double-NAT and more...
Poppapete
The Ubee won't be doing NAT, it is now dumb once you bridge it. Any device that you plug directly into the Ubee will not be connected to the original LAN.  You in effect can have a second totally separate LAN. Don't know what rules TWC have about a 2nd or even 3rd external IP as I live in an insignificant little place called Australia without TWC. Others will know TWC rules regarding this.
dvn
Ok. I think I will put the Ubee into bridge mode and let the Luxul do the rest. Seems like the simplest solution. One AP - all with same SSID and pw.
Any thought about guest networks? Enable? Don't bother? What are you guys doing? Thoughts about wireless bandwidth when guest is enabled and being used?
ikon
I agree with Poppapete. I think your proposed solution is a good one.
Whether or not to enable Guest Networks depends on whether there will be guests. If there will be, then I would enable it. Also, I believe some people use Guest Networks to isolate Xbox and PS3/4 devices from the main network.
Poppapete
Exactly. If you are have a spare wireless router just plug it into a 2nd Ubee port (when bridged) and presto you have a guest network that is entirely separated from your "private" LAN.
dvn
Poppapete, I like it. I may end up using that idea.
Thanks all for the feedback. It was a great help.
ikon
But you need a 2nd WAN IP from your ISP, right?
Poppapete
Correct. Here in Australia I use Telstra and have been using 2 for a couple of years without incident. I have been told some residential customers can get away with 3. To get more you must pay business rates ( more money). The modem must have the extra WAN ports of course.
ikon
In my experience, most ISPs won't issue more than 1 Internet IP to residential customers, which makes a 2 router solution like the one described impossible.
dvn
Roger that. I'll implement the config I've worked out with your help and see how it goes. I'm anxious to see the green CrashPlan icon in the tray once more.
LoneWolf
I agree that the best thing to do with that setup is to bridge the ISP modem so that is is just that (only a modem). It shouldn't be to hard to find the model number and get a user manual. You may find that it can't be bridged.
Edit: A quick google search came up with this.
http://www.dslreports.com/forum/r28428899-How-do-i-put-new-Ubee-modem-in-bridge-mode-
and this
http://www.dslreports.com/forum/r29247502-UBEE-DDW365-Bridge-Mode
This.  Note that TWC should be able to put their modem in bridge mode remotely via a call to tech support as well.
That's the main issue with the config.  If it's the Ubee modem I'm thinking of, it's one supplied for people who might do voice as well.  If the client isn't doing voice, it's a lot easier to go out, get a Motorola SB6121 or SB6141 cable modem that doesn't have Wifi or the four-port switch (and voice setup) and switch to this.  That way, the client isn't paying for the monthly lease fees for the modem either, because they've bought their own.  This is exactly what I've done with Comcast.
If the client does VoIP through TWC, they are probably stuck with the Ubee.
    • JROrtiz
      By JROrtiz
    • Jason
      By Jason
      Have been running a Windows DHCP server on home WSE12R2 box for quite some time behind my Sophos UTM firewall. Also allowed me to seamlessly run Windows Deployment Services at home. WDS just worked.
      But if I needed to make a particular LAN IP address exception on the firewall, I had to 1.) create a Windows DHCP server reservations AND 2.) create a network definition for that IP on the Sophos UTM box. 2 steps. Not very efficient; was sure I was doing something incorrectly...
      Tried to migrate to Sophos UTM running the DHCP Server, but now WDS doesn't work. LAN devices can no longer PXE boot. Seems possible. Many guides. None have proven especially successful.
      Is it possible to run a Windows DHCP server and have Sophos UTM import DHCP reservations instead of maintaining 2 unique entries for each IP reservation (one in Windows DHCP, another on Sophos UTM box)?
      What is best practice?
    • donschmidt
      By donschmidt
      Good morning.  I've just  purchased a home still under construction and plan to have CAT6 installed throughout the living areas. I'm hoping that someone can advise me as to the specific quality/specs of cable that I should use.
      Thanks and Happy New Year.
    • Joe_Miner
      By Joe_Miner
      I've been looking at the Intel Compute Stick BOXSTK1AW32SC and was wondering if anyone here has experience with that and if the Intel AC 7265 built into it is backwardly compatible with older N and A,B wifi?
    • heavy21
      By heavy21
      I want to optimize the performance and security of my home network of servers, PCs, laptops printers, smartphones, TVs, etc.  Current network appliances include layer 2 and 3 switches (Cisco small business) and Linksys router.  I’m looking to replace the Linksys with a security (pfSense) router appliance (w/OpenVPN).  I will also be adding security cameras and a NVR to the network.
      The gigabit network is straightforward in structure with all Ethernet connections hanging off the24 port switch connected to the cable modem and router except a cascaded 8 port switch in a room to provide 4 Ethernet connections in a room with only one data port.  Wireless connections presently come off the Linksys but will eventually come off the to-be-purchased security/router appliance with a wireless card.  I don’t see more than 100 devices in total for the whole network.  No VLANS and no sub-netting.  All hardware supports IPv6.
      Hardware line up is:
      Dual Zeon server w/RAID 10 of 24 TB of storage, 64GB memory
      Cisco managed switches layer 2 and 3
      HPEX495 server
      Workstations, Desktops, Laptops, Tablets, iPads
      Printers
      Software line up is:
      Windows Server Essentials 2012 R2, single domain controller, storage and file server duties
      Windows 10 Pro all non-server Intel computing devices
      PLEX server for streaming audio and video to display units
      Office 365
      From what I’ve read so far, it appears that I need to incorporate an IP addressing scheme for clients and servers on the network.  It would also appear that I need to implement VLANS and/or sub-netting to protect access to certain files and security footage, provide guest networking with future consideration for electronic door locks and some sort of server based media distribution to various display devices,
      What are best practices on assigning client and server devices to IP ranges, fixed or dynamic IP addresses?  Do I need to assign clients or servers to IP ranges?  What are the considerations in establishing sub-nets over VLANS or vice versa?  I’m pretty sure I want to restrict access to cameras and their security footage and personal files on my workstation.
      Thanks for any resources and advice provided.
