Fanless power supply Fortron FSP 150-50TNF possible?
Saburr
Hi,
i was searching around, to find some facts about the PSU, which is original build into the Gen8. I wanted to know, which class it is (80 Plus,...).
I also find another PSU which is also formfactor Flex ATX: Fortron  150-50TNF
It is >80% with the efficiency.
Datasheets:
Specs:
https://www.secomp.de/i2cmsdata/pdf/s19/19102205_spec_111.pdf
Drawing:
https://www.secomp.de/i2cmsdata/pdf/s19/19102205_draw_111.pdf
I don't know, if this is possible.
Maybe the idea is not practicable, then I am sorry, for open this thread.
Greetings
  • 8 months later...
The Flex ATX is a compact power supply unit and all the internal components are cramped together.
I think passive diffusion of heat could be an issue in the Microserver gen 8. The heat will negatively influence the lifespan of the PSU.
I would be interested to learn if someone swapped the PSU. The loudest component of my Microserver gen 8 seems to be the PSU fan.
